Old 10-11-2004, 02:43 PM
towser42 towser42 is offline
Post 93 Escort 1.9L How remove waterpump?
I changed my timing belt over the weekend and had every intention of changing the waterpump at the same time, as is usually recommended. However, after getting the bolts out, I could not get the large hose coming from the radiator off, to save my life. I tried from above, I tried from below and it would not budge (working space is pretty cramped, obviously). I managed to get the clamp to move, but it's like the hose is superglued to the pipe. (Now I can't get the clamp back onto the hose -- can't get enough leverage -- but that's another story). It also didn't look like there was enough room to pull out the pump, even if I had been able to remove the hose, even though I had removed the motor mount.
After four hours (!!) of trying (with a few breaks for cursing and fuming), I finally gave up, rebolted the waterpump in place and settled for just replacing the tensioner (came with the new waterpump), installing the new belt and putting everything back together.
Now, if my waterpump eventually fails and I have to do it all again, does anybody have any suggestions on what I should do differently?
Thanks.
Old 10-11-2004, 03:33 PM
Snow93 Snow93 is offline
Send a message via MSN to Snow93
Re: 93 Escort 1.9L How remove waterpump?
next time-buy a new hose.. cut the old one off.. get anew clamp(and if your usin spring clamps chuck em.. buy some screw type).. clean the connections.. you can save alota greif for the sake of 10 bucks.
Old 10-12-2004, 08:56 AM
Yeah it's a spring clamp. Hmm, I forgot about the screw type. That would be a hell of a lot easier. The radiator hose looks like it would be a real bear to feed through up to that point. Thanks for the advice, though. It's dumb, but the hose looked to be in such good shape that it didn't occur to me to cut it off. D'oh.
Old 10-12-2004, 05:25 PM
those old spring clamps start toloose there tention to.. and they will strangle the pipe causing bit of damage to it.. speaking of wich.. still gotta get mine off one day.
Old 10-12-2004, 10:58 PM
jman63 jman63 is offline
put a little baby oil or similar type lubricant on the inside of the new hose then when ya' finaly get it wormed around where it needs to be, it will slide right onto the water pump with no trouble....'cuz there's really no place to get a good solid grip on it to slide it on...yup.....spring clamps suck...
Old 10-13-2004, 09:36 AM
hmm.. that one ill have to rember..
