Old 10-11-2004, 01:18 PM
clawhammer's Avatar
clawhammer clawhammer is offline
Random shaking at acceleration
I just recently bought a 91 CRX, the check engine light was on when I bought it, but the owner said it came on because of an oxygen sensor, and he replaced the sensor, but didn't have the tool to reset the computer with. I put about 3000 miles on the car in the past 2 months, when I'm accelerating just normally usually when the engine is between 2000 and 3000 rpms, the car shakes maybe two or three times, and after that, everything seems fine. I'm thinking it might be connected to that check engine light. Maybe even a bad fuel pump or hopefully just filter. What do you guys think?
Old 10-11-2004, 04:17 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
The only tool you need to reset the computer is a pair of needle nose pliers. Pop the hood, theres a fuse box on the left side (when facing the front of the car) on top of the strut tower. Open that up and pull the Hazard fuse. Keep it out atleast 15 seconds then pop it back in. Your computer is now reset
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 10-11-2004, 06:35 PM
bionictony's Avatar
bionictony bionictony is offline
Send a message via AIM to bionictony
Re: Random shaking at acceleration
when the car is not moving and when you rev the car to 2000-3000 rpms does it shake? if it only shakes when you're driving at 55mph and up and accelerating then it's most likely the inner cv boots. that was my problem.
Old 10-11-2004, 08:48 PM
we were just talking about that in class today
ZC stuff
Old 10-11-2004, 10:15 PM
anthony90si anthony90si is offline
that happened to me and it turned out that the bearing was bad on the dizzy...
Old 10-14-2004, 04:53 PM
clawhammer's Avatar
what is the dizzy?
Old 10-14-2004, 07:20 PM
distributor
ZC stuff
