| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
I have been wondering about his for a long time now.
Doesn't a large FMIC like a GReddy 24r block airflow to the radiator? Do I need to worry about it? |
Re: How does a large FMIC affect air flow to radiator?
Re: Re: How does a large FMIC affect air flow to radiator?
Then dont assume that everyone else doesnt have AC. I think you know well enough that most poeple have it. Be carefull in your recomendations. Thousands of people read forums and base thier purchasing decisions on what they read.
I dont think either greddy will give you too much trouble with the AC off. A local member has a very small griffin/RRE setup though and does have trouble when the AC is on. WIth a 24x10x3.5 I had no troubel at all with my AC condenser removed. But going to a 2" taller 24x12x3.5 even on the highway temps will climb when its over 90 degrees, unless I turn both radiator fans on (in DSMlink, or by turning the AC on. Its gone, but the system will still kick on the other fan). Proper fan setup and ativation, and proper shrouding of the FMIC and radiator go a long way towards keeping things in control. You can get even fancier with hood extraction vents, etc. Hope that helps.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
Thanks guys. I dont operate my AC EVER...(California weather)...so do I still need to worry about manually operating the fans, or is it c0ol?
Hard to say. You'd have to find someone with the same FMIC that lives at the same climate. I assume like Kevin, that you will be fine with AC off. Better fans aren't that expensive anyway.
Actually the stock fans are aobut as good as they get, especially the main pass side fan (for 2g). Just having the AC off can still cause trouble though since the air still has to pass through the FMIC, then the AC condenser, before it gets to the radiator. No harm in trying it. But if you really dont use the AC you might want to just pull the condenser. To do the right thing, go to a shop that does AC work, they can recover all of your old AC gas/fluid. I took mine out in such a way that I Can always reinstall it if I feel the need. With the AC removed, the AC switch can still be used ot toggle the secondary fan if necessary.
Couldn't you just ghetto rig some kind of vent from the side opening in the bumper to the radiator or make one of those CO2 sprayers for the radiator? Probly not, just thinkin of stuff.
![]() '99 GSX, 5-speed, 60k miles: Greddy filter / RRE uicp / 1g bov / Autometer boost gauge / Injen-copy intake / Megan DP (not installed) Coming soon! Thx to Blackcrow & nova1313! http://dsm-one.org/ Adopt pets in need! http://www.petfinder.com/
Sorry, my home country has a steady climate of around 130F during summers as normal, so Im more used to heat than a lot of other ppl... CA weather as an aggregate still rocks.
is there a way u can cut into the A/C fan wires and rig a toggle switch to turn it on at will?
![]() 1998 Eagle Talon TSi AWD 6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband |
