Old 10-11-2004, 11:48 AM
djstorman djstorman is offline
Send a message via MSN to djstorman
93 civic overheating !!!
Allright let me give ya the information.
I bought this civic about 2 months ago and everything was going fine except that the hose connect on radiator was cracked and broken.
My wife replaced the radiator and then I replaced the thermostat while I was fixing the car. I also recharged my ac which isnt working but that is another matter.
For the past 2 weeks the engines has been overheating when it is driven for more that 5 minutes.
So last night at around 2 am on my way home it started again and I dont know what to do ?
Also just another piece of information.
Before my wife changed the radiator we noticed that there was too much oil in the car. So after she replaced the radiator I changed the oil filter and drained the pan... There was no water in the oil.
So i need help I dont think its the radiator I just changed the thermostat so what could it be ??
Old 10-11-2004, 01:35 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: 93 civic overheating !!!
water pump maybe. Are you losing coolant at all?
Empty Pockets Racing Member #1
Old 10-11-2004, 02:45 PM
coolant loss
my wife checked the radiator last week and said it was full today it was totally empty so I guess yes there is coolant loss. However there are no leaks when I look for any.
Old 10-11-2004, 07:04 PM
dat1laosguy's Avatar
dat1laosguy dat1laosguy is offline
dunno your head might be warped
damn i can barely see you in my rearview mirror
Old 10-11-2004, 07:17 PM
update on the situation
Allright new developments.
I noticed today after I had finished driving the car for maybe 10 minutes that there was coolent loss in a steady stream not a quick stream but still a stream, from the left side looking foward of the engine. Dont know if it was from the engine but it was some where fromthat general area.
Is that the water pump or something worse. Help !!!!!
Old 10-11-2004, 07:57 PM
fiercecivic's Avatar
fiercecivic fiercecivic is offline
Send a message via AIM to fiercecivic Send a message via MSN to fiercecivic
could be ur haed gaskey, i had to replace mine bout a month ago. Also check all ur hose connections and, put teflon tape on all ur threads that connect to the coolant system
Old 10-11-2004, 09:14 PM
checing head gasket
Is there a way to check to see if the head gasket is blown ??
like check the cylinders or something ?
Old 10-11-2004, 11:03 PM
I guess I will test with a pressure meter and see if its blown any suggestions or tips for me changing my head gasket ??
Old 10-11-2004, 11:42 PM
93CivicLx's Avatar
93CivicLx 93CivicLx is offline
what is up with "93" civic's this month. Mine is overheating too.. I notice my fan doesnt come on anymore when the temp gauge goes past 3/4's near H "hot". I don't know what caused it to go out? I check fuses hood,dash.. all ok. I the harnest wiring seems to be all connect too. I guess i have to just buy a new fan... Unless others have any other suggestions?
"H to the izzO N to the D A"
-Spell CiviC backwards- It's all great from front to back-
My car proflie http://www.cardomain.com/id/intoxicivicated
Old 10-11-2004, 11:45 PM
checked my fan it works
My fan works so I am not sure what it is. Although I suspect it to be my head gasket dont know yet I guess I miht check with pressure tester
Old 10-11-2004, 11:49 PM
GScivic7's Avatar
Re: Re: 93 civic overheating !!!
try replacing the relay for it.
Old 10-12-2004, 03:08 PM
compression test results
allright here are the results from my compression tests
spark plug hole number 1- 180
spark plug hole number 2- 170 Water squirting out
spark plug hole number 3- 170
spark plug hole number 4- 180
So is my guess right when I say that the headgasket is blown between 2 and 3 ??
Need some information if you think this is correct.
Old 10-12-2004, 10:06 PM
Update
Allright I finished taking out my exhaust and intake manifold. I am realy glad that I put in an extra 5 dollars for that can of bolt and nut lubricant/breaker. Going to start the head thursday. So any suggestions or tips. Also is there a way for me to see if I warped the head or would it be easier to take it into a shop ?
Also I also heard that if the head is warped that the bolts are going to be bent is that correct ? I am a true newbie so dont hold back give me all the advice you have. Thats it for now, thanks for all the help guys
Old 10-12-2004, 11:10 PM
GScivic7's Avatar
if you have a feeler gauge or something like that, just run it along the bottom of the head and see if there is any inconsistencies. If there are, you can get it resurfaced (look in that the thread "higher compression?").
Old 10-13-2004, 05:12 AM
Silverbolt Silverbolt is offline
Exterior Guy
Send a message via AIM to Silverbolt
Check your thermostat: Heres how....
Originally Posted by superbluecivicsi
An easier way is:
Warm the engine up until it gets hot. If the engine is hot and the upper radiator hose is still cool, then its your thermostat. If the upper radiator hose is hot, then the thermostat is fine.
If its not that, check for leaks. Another common problem is a faulty "fan switch". Its a metal piece that screws directly into your motor... located towards the back of the motor... kinda behind your distibutor cap.... and it has a plastic plug, plugged into the top of it. Honda retails it for about $45. You can buy a Mugen one for $50... but you'll have to get a Mugen Thermostat for $85 for it to work as it was designed to. The Mugen setup turns your fan on at 80, instead of 93 degrees.
"Take your time, do it right, and NEVER settle for less."
"The only stupid question, is the question not asked."
