Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 10-11-2004, 09:16 AM
ieyecare ieyecare is offline
Exclamation Help!:radiator Fan Won't Shut Down!
The radiator fan stays on even after shuting down the engine, even though I never got a warning light on the dashboard. Could it be the computer?? The on/off switch?? It's a 1999 BMW 323i. Thanks for the help!
Old 10-11-2004, 11:56 AM
jeffreyb4me jeffreyb4me is offline
Re: Help!:radiator Fan Won't Shut Down!
Replace the 'Normal Speed' relay in the fuse box. The contacts overheat, burn and then stick closed draining the battery until flat. It should be the last relay in the left rear corner of the E-box, yellow and have 5 pins. with the key on and that fan running, pull it out and if the fan stops, you've found it.
It's likely the dealer won't find it by description, they'll need the number off the old one.
Old 10-11-2004, 01:23 PM
Re: Re: Help!:radiator Fan Won't Shut Down!
Could you tell me where I can find the E-box at? I don't have a manual to look it up. And thank you for your prompt answer. I will check it out at soon as possible. God bless!
Old 10-11-2004, 03:05 PM
E36 ='s L/R corner of the engineroom, E46 ='s the R/R corner.
Note, the problem's common on E36's, can't recall on E46's amd I'm home now and can't check further.
stay in touch.
