Go Back   Automotive Forums Car Chat > Honda > Integra
Old 10-11-2004, 03:00 AM
B18c_all_da_way B18c_all_da_way is offline
stand alone vs chiping ECU ????
which one would be brtter for me cuz i want to go N/A,and how much better is the stand alone towoeds just chping my ecu with like a skunk 2 chip ??? i need some advice from da pro's ,,Thanks for the advice.
Old 10-11-2004, 02:51 PM
LSfrankenstein LSfrankenstein is offline
Banned
Re: stand alone vs chiping ECU ????
skunk2 chip raises rev limiter above 9000 rpm so be careful with that one. My friend installed a skunk2 on his 93 GSR and it made a noticeable difference id be scared of the rev limiter tho we've all accidentally taken rpms up that high wouldnt want to fuck up your valve train u would get valve float that high.
Old 10-11-2004, 03:17 PM
Re: Re: stand alone vs chiping ECU ????
much recpect thanks a lot bro
Lex
Old 10-11-2004, 03:20 PM
wickedplastikman wickedplastikman is offline
i had a hondata s200 and then switched to the aem standalone. i had a lot of problems getting the car to idle under heavy loads that needed to be worked out. for this i would reccommend a piggy back system. the hondata worked pretty good and it was nice because most of the programming was factory done and all the hondata did was change what i wanted to change.
99 teg ls turbo:
Drag gen III turbo, Blitz BOV, Blitz Boost Controller, AEM Standalone ECU, MSD Ignition, MSD Blaster SS Coil, MSD Cap, Skunk2 Intake Manifold, AEM Fuel Rail/Fuel Pressure Regulator, ACT XCT Clutch, ACT Aluminum Flywheel, Nex SS Coilovers, Thermal Stainless 3" Exhaust, Skunk2 Short Shifter/Knob, Rota 15" Black Slipstream Wheels, Falken Azenis Tires, Brembo Rotors, Axxis Metal Masters, Type R Wing/Seats, VIS Carbon Fiber Hood
Old 10-11-2004, 03:32 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
It seems to be a problem for AEM, getting a good idle I mean. I have a friend who had his car tuned and the idle was never good; it'd jump up and down and then get lower and lower until it'd just stall. A few people have told me that it's a common problem.
Old 10-11-2004, 04:01 PM
thanks loco
Lex
