Go Back   Automotive Forums Car Chat > Honda > Integra
Old 10-11-2004, 03:44 AM
B18c_all_da_way B18c_all_da_way is offline
All Moter N/a Gsr ????
look guys i need your help,I need some help on what are da best things to do to my gsr ,cus i want to go N/A all moter ............???? thanks
Old 10-11-2004, 03:18 PM
LSfrankenstein LSfrankenstein is offline
Banned
Re: All Moter N/a Gsr ????
going N/A pretty much means your going to be rebuilding your entire motor. You should get a stroker kit with a deck block and some CTR pistons and CTR cams and beefy rod bolts. oh u'll need new valve springs to prevent valve float and u can get like a skunk2 piggyback ecu to raise ur rev limiter past 8100
Old 10-11-2004, 07:34 PM
b18 ls's Avatar
b18 ls b18 ls is offline
Banned
Please do not listen to any of lsfrankenstien's post. He is here for comical reasons only. After you've gotten intake, headers and exhaust, you should get new cams, cam gears, and valve/valve springs. I would always recomend skunk2 camshafts for a vtec b18, or b16. After that, you can get new pistons.
Old 10-11-2004, 07:56 PM
thanks
yo thanks for your help man rescpect ..
Lex p.s i'll link yu after i do all thoes things , to see whts next
Old 10-11-2004, 11:45 PM
LSfrankie's Avatar
LSfrankie LSfrankie is offline
Banned
that up there was a serious post btw. how is it bs?
Old 10-11-2004, 11:58 PM
Xtreme_098's Avatar
Xtreme_098 Xtreme_098 is offline
Send a message via MSN to Xtreme_098
We'll, your going to have to rebuild your motor in order to do anything really. If you going all motor, well, yea you would rebuild the motor or it wouldn't really be all motor. You will blow your motor if you boost and don't rebuild it. Unless you boost at a low psi and thats not fun. I would recommend using Skunk2 for what you can. All their products are race proven and very reliable (www.skunk2.com). Use high compression pistons for a while. If you decide you want to boost, swap them for a lower compression piston. If you don't, you still have the high compression pistons. Save your money and do what you want to do.
Old 10-12-2004, 01:43 AM
thanks a lot man much appreciated
Lex
