Old 10-10-2004, 10:59 PM
barnbash barnbash is offline
1999 Camaro will not start
I have a 1999 Camaro Z28 that has an INTERMITTENT NO start problem. The engine cranks and the battery is new. The engine just cranks and starts occationaly like there was no problem. The car runs great once it is started although it can take 15 min to start it. Any Ideas would be appreciated.
Thanks.
Old 10-11-2004, 12:14 AM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Re: 1999 Camaro will not start
Could be something with the VATS, make sure the pellet on your key is clean...
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 10-11-2004, 02:13 AM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
welcome to the forums
Doesnt sound like VATS.. If thats malfunctioning the car usually wont crank..
fuel delivery problem? when you turn the key to ignition do you hear your fuel pump turn on? wait til it shuts off than try start the car.. see if that helps any
1991 Camaro Z28
Old 10-11-2004, 10:16 AM
jackandjill jackandjill is offline
How many miles does it have?
Could be fuel pump, as DaMoNe6969 suggested. If it's been a while since you've changed the fuel filter, might as well do that. When turning the key to the "on" position you should hear the fuel pump turn on for a couple seconds.
A few other things..
How's the starter sound? I had to very recently replace my starter, had an intermittent starting problem. If it whines or doesn't crank the engine at all, may need to be replaced. (Most of the auto shops can diagnose starters).
Does the car start easily when warm?
Old 10-11-2004, 09:05 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
look into your fuel pressure regulator as well.
Old 10-22-2004, 01:25 AM
timetowinarace timetowinarace is offline
Send a message via MSN to timetowinarace
I have the same problem with my '96. just started. It seems to happen warm. Starter is good. I can hear the fuel pump run. Must be filter. I need to fix it as I have to sell.
Old 10-22-2004, 01:46 AM
'97SLVRBullet's Avatar
'97SLVRBullet '97SLVRBullet is offline
Send a message via AIM to '97SLVRBullet
Re: Re: 1999 Camaro will not start
Is it a Z?
97 Z28
C.A.I. Edelbrock shorties,all free mods,Borla's,MSD,LT4 timingchain, 1.6r/r,LT4 cam, NGK,p&p heads,ported maf ,52mmTB adj fuelpressure reg.,373's,pcm tune by pcmforless, all poly bushings,spohn t/a, s/t brace, etc. What I don't have..no egr no air pump and no cats
Well dip me in chocolate and
throw me to the lesbians!!!!!
Old 10-22-2004, 08:25 AM
Not a Z. Just v6 coupe.
