Old 10-10-2004, 10:41 PM
superXracing superXracing is offline
best source for an inexpensive filter
to replace the shot one on my Injen? I don't want to spend big bucks for an authentic replacement. eBay?
Old 10-10-2004, 10:56 PM
coolguycooz coolguycooz is offline
dude just buy a K&N i know it seems like its way to expensive but its worth it life time warranty cant go wrong with K&N its big and it probalby filters better then anything out there so just spend the 80 bucks to get the K&N.
Old 10-10-2004, 11:15 PM
george536's Avatar
george536 george536 is offline
Re: best source for an inexpensive filter
juss get a 10 dollar one off ebay.
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 10-11-2004, 01:42 AM
kjewer1 kjewer1 is offline
AF - Advisor
A god quality K&N filter is only 30-40 bucks. Try www.summitracing.com. I got my 7" by 9" there for like 35 bucks. For that price its hard to justify buying a no name POS.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-11-2004, 11:05 PM
Is that the dimensions I need? 7" base? Thanks.
1995 Talon Tsi 5spd. White, 03 GTS wheels, Injen Intake, HKS super seq BOV, Greddy upper IC pipe, el-glo gauges, HKS turbo timer, Autometer Boost and AF gauges.
2003 Nissan 350z 6MT, Redline, 19's, 100 shot NOS fogger, many more mods...
1997 Honda del Sol FOR SALE!!
Old 10-12-2004, 01:54 AM
AF - Advisor
Depends on your setup. My filter is massive, and is on a 4" intake pipe. You cna see pics at my site. Its the largest filter that will fit between the fuse box and headlamp (7", cylindrical, not cone). For a more typical setup you may not be able to find that size filter with the right size inlet. And for a stock MAS, you need an oval inlet for the FIPK type setups, or round (3"?) for the cheap/ebay style adapters.
When looking at the filters in summit there are some drop down boxes that let you input some information. So you can narrow down the results. For example, have it show only 3" inlets. Then show only cone shape. Then narrow it by length, etc....
Kevin Jewer
Old 10-12-2004, 03:39 PM
dsmodder dsmodder is offline
Send a message via AIM to dsmodder
hey i just ordered a the MAF adapotr and a filter off ebay. ill sell you the filter it came with cuz im replacing it with a K&n. inside diameter of the filters flange is 4.5 inch. [email protected]
Old 10-12-2004, 10:46 PM
Re: Re: best source for an inexpensive filter
I have the MAF adapter (with the Injen) so you just have a new generic filter?
Old 10-13-2004, 02:13 PM
email me at [email protected] the filters adaptor inside diameter is 4.5 in.
Old 11-17-2004, 12:04 AM
Actinide's Avatar
Actinide Actinide is offline
Send a message via AIM to Actinide Send a message via MSN to Actinide
Where are you guys finding the FIPK for $35 or even $80? I've been checking around and all I see are over $100.
'97 Eclipse RS
- AEM Cold Air Intake
- MONZA Cat-Back exhaust
- 2.5 inch drop
Old 11-17-2004, 07:51 AM
real_madridcf's Avatar
real_madridcf real_madridcf is offline
Send a message via AIM to real_madridcf Send a message via MSN to real_madridcf Send a message via Yahoo to real_madridcf
K&N!
95 Eclipse GS: OBX Full Exhaust System, OBX Headers, OBX Short shifter, OBX Spark Plugs & Wires, 17' MSR Rims w/ Wanli tires
96 Eclipse GS-T : K&N Filter w/ Hardpipe, UICP & LICP, Greddy Type S bov, Greddy Boost Gauge
Hala Madrid!
Old 11-18-2004, 05:27 AM
AF - Advisor
If you just need a particular size filter, www.summitracing.com is where I go. I paid ~34 bucks for a 9" long, 7" diameter cylindrical with 4" connection. If you need to adapt it to the stock MAS you can do the KN FIPK for about 80-90 bucks or get a 20 dollar ebay adapter (that blocks half of the MAS by the way) and a standard filter from summit. I would rather spend the money for the FIPK, you only have to buy it once.
Kevin Jewer
Old 11-18-2004, 09:14 PM
nah my ebay adaptor doenst block off my MAF honeycombs at all. i know the ones your talking about though. they fit like a 3 in outside diameter filter. you just gotta look around. heres a pic of the one i got for 8.99 plus 15 bucks shipping lol. its the pic from dejontool.com and im not lying this adaptor is identical to mine. scroll to bottom of the page. http://www.dejontool.com/DSM%202gC%20Intake.htm
this is the ebay seller i got it from. i recommend. he sent me trackin number and the works. makotoautotrends
Old 11-18-2004, 09:16 PM
oh also. the reason why they are cheap on ebay is because they only include some china filter and the adaptor. the k&n kit comes with a "bracket" i guess you could call it that holds the fitler in place. i built my own out of some sheetmetal and the rubber bushings from my stock airbox so that when the engine moves so does my filter.
Old 11-19-2004, 10:27 AM
AF - Advisor
That adapter looks like it will work fine! Not all filters are created equal though, even if they look like K&Ns. And it looks like I had already replied to this thread a month ago, LMAO. They all look the same after a while i guess...
Kevin Jewer
