Go Back   Automotive Forums Car Chat > Ford > Econoline
Old 10-10-2004, 08:52 PM
Vrmaniac Vrmaniac is offline
90' e150 Starts fine, runs until op temp. then dies.
I first thought it was the modulator, which did end up being faulty, but when I replaced it. It still does this! So I checked to see if it was overheating, I noticed the coolant was not flowing so I replaced the thermostat, and it is working as it should.
Now when I replaced the ICM i had to unbolt the dizzy, so its probably out of exact timing, but it starts and idles fine for those first few min's.
After warming up i still get sparks to the wires. Not sure where to go from here.
Old 10-15-2004, 12:44 PM
Well, turned out to be the fuel filter. I knew it was something involving fuel when i tested the spark while it wouldn't start after running.
Hope this helps someone else in the future.
Old 01-29-2008, 11:20 AM
G0ldRush's Avatar
G0ldRush G0ldRush is offline
Re: 90' e150 Starts fine, runs until op temp. then dies.
I'm having the same problem van stars fine for 5 mintes thens dies, I will change the fuel filter for sure
If they don't have it, I don't need It!
Old 01-31-2008, 03:28 PM
G0ldRush's Avatar
I found my problem today, i took my frame pump off and bench it if I had some power on it it did work so i test continuity on the wires and notice that the black one has none so i put a new wire and connector on the pump put back in the van and van is working like new
