Old 10-10-2004, 08:29 PM
whiterob whiterob is offline
new to subs/amp need a little help
alright im new to the whole car system thing, but i finally got some cash saved up and want to get a system. i am planning on getting 2 jl w6v2 which are 400rms dual 6 ohm? i am really confused on what kind of amp to get. 2 channel? 4 channel? whats does 600W RMS (continuous) x 1 @ 4 ohms, bridged mean? i was looking on best buy website and they have rockford fosgate amps with 1800 watts but i dont know if thats enough rms to power for 2 subs. thanks
Old 10-11-2004, 12:41 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: new to subs/amp need a little help
you should get something that does around 1000x1 at 1.5 ohm, or 1500x1 @ 1ohm
what is your budget for the amp?
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 10-11-2004, 10:37 AM
probly around 800. i was looking on ebay and found a few jl 1000.1. would that be good? and why would it be 1 ohm? thanks
Old 10-11-2004, 03:33 PM
sr20de4evr's Avatar
Because no one ever advertises a 1.5ohm power rating (except for JL, because they're subs are some of the only ones that can be run at 1.5ohm), so instead of hunting around for an amp that is rated at 1000x1 @ 1.5ohm you can just find an amp that does 1500x1 @ 1ohm, because an amp that does 1500x1 @ 1ohm will do ~1000x1 @ 1.5ohm.
Anyway, yes a 1000/1 would work, as would many many others. $800 can buy you a lot, you could get a 1000/1 unauthorized with no warranty, or you could get an equivalent amp for the same price from another company that's fully authorized.
These would be my choices, keep in mind I would take any of these over the 1000/1 simply because I like owning equipment that no one around me has. They're all very very good amps, and I've heard many tales of JL amps sounding kind of "dry" and not too lively, which is another reason I would go with one of these over a JL. After quite a bit of research I ended up picking the Cadence myself and I don't regret it at all.
Cadence ZRS-8
DLS Ultimate A3
US Amps DE-1000
US Amps USA-1000
Arc Audio 2500-CXL
Audison VRX 1.500
'01 Black Sentra SE
'05 Silver WRX STi
Old 10-11-2004, 03:46 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Elemental designs nine.1... www.edesignaudio.com
315 shipped. or a trutech amp... Cadence is fun. Personally I would get a nine.1 and work on other parts of your system that probably need improvment like say another amp and some components or maybe a new headunit...
www.cloudcity.deviantart.com
Old 10-11-2004, 07:09 PM
how many watts are equal to 400 rms? if a amp is to powerful can you control how much power you use?
Old 10-11-2004, 07:43 PM
sr20de4evr's Avatar
Re: Re: new to subs/amp need a little help
400 rms is 400 watts, rms just stands for "root mean square", it's a method of finding average power instead of peak power, which some other companies use because it makes them look better. rms power is the power you should always look at
And yes, you can turn down the gain slightly, or just not turn the volume as high. You can run a set of 100rms components on a 2000rms amp if you want, as long as you don't crank the volume and push the speakers past their limits (which you could do with a 100rms as well) then the speakers will be just fine. I recommended a 1000rms amp so you could get 500 to each sub, to give yourself a little headroom.
'01 Black Sentra SE
'05 Silver WRX STi
Old 10-12-2004, 01:09 AM
alright every day i am learning more and more and this is a stupid question but how will i know when i might be pushing my subs to far? i ordered 2 12 w6v2's today now just waitin on a little more cash to get the amp.
Old 10-12-2004, 01:16 AM
sr20de4evr's Avatar
if they're making funny noises or smelling, then you're pushing them too far
'01 Black Sentra SE
'05 Silver WRX STi
