The horn in my 96 cav is not working, but it makes a clicking noise. Where do u find the horn and how do you fix it?
Re: 96 cav horn not working,clicking
Sounds like your fuse is blown, check your fuses and make sure its not blown because mine was doing the same thing and just turned out to be a blown fuse
Re: Re: 96 cav horn not working,clicking
checked fuses. no problems there. thanks anyways
Cavalier horn
Well if it is making a noise like clicking usually means horn is either not hooked up or no good try using battery terminals and direct connect them to the horn witch should be located under the front passenger fender at the very front right side and if horn sounds then it is ok and go to fuse or check wiring
good luck!! |
