Old 10-10-2004, 05:10 PM
supratuner89 supratuner89 is offline
does anyone know how to remove.....H2
does anyone know how to remove the door handles, rear view mirrors, and the trunk bin (dont know what it is called) from a maisto H2 SUV.
prepping for paint so im removing everything.
I dont know who did it but someone exchanged the matte black parts from an H2 SUV to an H2 SUT's chrome parts.
I think it was gafoto...not sure.
but anyway that is what i want to do.
PS what do you recomend:
Spray can OR airbrush
Old 10-10-2004, 08:25 PM
Entity_101's Avatar
Entity_101 Entity_101 is offline
Re: does anyone know how to remove.....H2
usually on all of my models including a maisto ferrari f50 if y ou get somthing as simple as a knife or blade you can fit it in at the glue points or around the areas where they connect (stuff like door skins) and then you just slowly and gently lever it in different spots being careful not to damage the plastic working along the whole piece. eventually it will get looser and if you have to you can go back and concentrate more on the glue points (whatever they are called... where they are glued on.)there may be some chemicals used in paint stripping that dont damage plastics but weaken the bonds from the glue but im not sure, youll have to check with the faq on that one. sounds good on the chrome and do you already have an air brush? if you do id say go for that as you can mix your own custom colours, make it look unique and stand out from the pack. Good luck on this project
Is that a metaphor or are you just speaking crap.
Old 10-10-2004, 08:51 PM
ModifiedCars04's Avatar
ModifiedCars04 ModifiedCars04 is offline
I'm not sure what you are talking about, can you post some pix Please?
" A old wise man once told me something, I simply replied I have a bad memory, that, david is way I can't tell you what the old wise man said "
Old 10-10-2004, 08:55 PM
Entity_101's Avatar
Re: Re: does anyone know how to remove.....H2
who was that directed at, if it was me im sorry i don't have a digi camera but it just involves seperating the parts from the body using a knife or lever.
Old 10-10-2004, 10:22 PM
PETET's Avatar
PETET PETET is offline
maisto??
door handle??
take the door trim off just push it out with screw driver
bin??
push out the light first. then there will a be a small + screw that u need to undo.
hope thats what u asking.. mmmm
[PROJEKTZ]
Old 10-10-2004, 11:24 PM
yup
i got it thanks
by the way are there any good low priced airbrushes
Old 10-11-2004, 01:55 AM
KustmAce's Avatar
KustmAce KustmAce is offline
Grande Boleros de Fuego
Sure! You can make one yourself.
All you need is:
A straw
Paint
Your lungs
MAKE ART, NOT WAR
Old 10-11-2004, 08:04 AM
wow how does that work
sounds pretty stupid
what if your if your sister comes up behind you and hits you in the back and you inhale really fast.....
........ wonder what paint tastes like.
Old 10-11-2004, 03:10 PM
Rubberband Man's Avatar
Rubberband Man Rubberband Man is offline
Send a message via AIM to Rubberband Man
OMG
Old 10-11-2004, 03:23 PM
cwmax cwmax is offline
yup
i got it thanks
I've used the Paasche VL for years. Never tried anything else. They can be had for around $40.00
http://www.dixieart.com/PaascheVL.html
Might try eBay also.
