Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 10-10-2004, 03:47 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Post 84 Caprice Voltage Guage Issues - Help!
I bought a voltage guage from a garage sale for my '84 caprice (along with some other guages). I wanted to know exactly whats going on under the hood while I'm driving, even thought the car runs beautifly. Anyway, the voltage guage didn't come with any installation instructions or diagrams. I was wondering if theres any particular place that the guage has to be wired to, or can I just hook it up to any power source. I want to get an accurate reading. Thanks!
Old 10-10-2004, 06:35 PM
TommySS TommySS is offline
Re: 84 Caprice Voltage Guage Issues - Help!
You can wire it into any circuit you want, but most folks tap into a switched 12v.
Depends on what you wanna do. Switched means there's no drain when the car is off.
Old 10-22-2004, 10:25 PM
PeteA216's Avatar
Okay, I hooked up the voltage guage to a wire thats live only when the ignition's on. Problem... when i turn the ignition on it stays at 8 volts, whether the cars started or not. I could rev it a little, but still no change. I know that theres no way that theres only 8 volts coming outta the car. Does this mean that the guage is shot?
Old 10-24-2004, 03:59 PM
Remove the gauge and hold it directly onto the battery terminals. What reading do you get? You better be getting a lot more than 8volts
What circuit did you wire this thing into?
Old 10-29-2004, 01:57 PM
PeteA216's Avatar
I still got 8 volts when I hooked it directly up to the battery. There are only 1 terminals on the back of the guage... a positive and a negative.
Old 10-29-2004, 06:45 PM
CD Smalley CD Smalley is offline
Are you sure it's not an amperage gauge rather than a voltage?
I bought a small 3 gauge setup once and didn't realize the one was an amperage gauge and needed to be hooked up differently. I don't recall what's different about hooking one up now though.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 10-30-2004, 07:17 PM
Wow. I never thought of that. I hope it's an amp gauge, because if all he's reading is 8 "volts", nothing on the car should be working as 10.2 = dead
Old 11-01-2004, 03:48 PM
PeteA216's Avatar
It's a voltage guage for sure, and everything in the car works great... lights, stereo, amp, horn, fan...everything. And the battery has never died on me yet. My best guess is that the guage is just crap. Like you said, anything 10.2 or below = dead, and everything seems normal.
Old 11-01-2004, 08:08 PM
Hmm.. I guess it's crap then. ;-)
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
