Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 10-10-2004, 03:39 PM
KaMaKaZiPyRo KaMaKaZiPyRo is offline
Send a message via AIM to KaMaKaZiPyRo
This Sux
What the hell do I do if I get water in my spark plug holes? My plugs come out all wet, and i know its water so what do i do?
Currently trying to piece together a Turbo CrVtec bubble hatch, expecting sumthin like 500hp?!?!?!
Old 10-10-2004, 04:54 PM
Civic_D16Y5's Avatar
Civic_D16Y5 Civic_D16Y5 is offline
Send a message via AIM to Civic_D16Y5
Re: This Sux
get a vacuum?
or just run the engine and hope ur engine doesnt seize tho i strongly suggest not doing that
http://www.carsponsorships.com/scout/sponsor.php?id=737
GET SPONSORED, QUICK
Old 10-12-2004, 09:22 PM
rubix777's Avatar
rubix777 rubix777 is offline
Send a message via AIM to rubix777
get some paper towels and absorb as much as you can, then try using a blow dryer.
Old 10-12-2004, 09:53 PM
cvcc_wagon's Avatar
cvcc_wagon cvcc_wagon is offline
Re: This Sux
run an air compressor line into there. then turn the engine over a number of times with the plugs removed. a little water never killed no engine tho, an old mechanics trick is to remove one of the vacuum lines from a carb and stick it in a bottle of water which in turn sucks the water through the engine to remove carbon buildup.
~Attention! if you are thinking about a D16A1 swap for your Civic/CRX and don't know where to start go Here. Thanks.~
Old 10-13-2004, 03:41 PM
goinbig goinbig is offline
Send a message via AIM to goinbig
Re: This Sux
Umm, running an engine with water in it is a bad idea!! Water will not compress when it is in the engine like fuel and air does.
Disconnect the sparkplug wires (all of them). Spray a little WD-40 in there (a little in each cylinder). Turn the engine over for a little bit, with the plugs still disconnected.
That should cause the water to displase enough that it will be fine.
Trust me, from owning a large selection of 4 wheel drive vehicles, WATER IS BAD FOR AN ENGINE!!!
