Old 10-10-2004, 02:16 PM
grandam96 grandam96 is offline
ABS and TC on 2000 Cavalier
I Have a 2000 2.2l Cavalier with 25,000 miles. My problem
occurs when I am backing up the car in reverse. When I
put the shifter from reverse to park or drive, the ABS, TC,
and Service light come on. When I turn the ignition off and
restart the car, the lights are no longer on.
Old 10-10-2004, 02:38 PM
86TATpi 86TATpi is offline
Take it somewhere and have it scanned for codes. Even if the light isn't currently on, the code is stored in memory. Not sure if a speed sensor would cause that problem.
Old 10-10-2004, 03:27 PM
princeal princeal is offline
I have a 99 Had same thing replaced wheel sensor fixed problem. You will have to have it coded so you can tell which sensor is bad
KJR
Old 10-30-2004, 03:08 PM
slowhand_4276 slowhand_4276 is offline
Re: ABS and TC on 2000 Cavalier
I had that same problem so I took in and they couldnt find anything wrong so they just cleaned my break system and they have not come back on since...Hope that helps!!!
