Old 10-10-2004, 01:55 PM
risin_outlaw risin_outlaw is offline
Send a message via Yahoo to risin_outlaw
91 lumina
i got at 91 lumina with a 3.1 in it & i got a problem with the exaust smelling bad & when you be running down the road you can be going 65 & lose speed, & when ya step on the gas it cuts out & i changed the following items, fuel pump, tps, coil pack, ecm, plugs & wires. im wondering if the timing or egr has anything to do with symptoms? any ideas?
Old 10-10-2004, 02:41 PM
86TATpi 86TATpi is offline
You may have a plugged catalytic converter.
Old 10-10-2004, 03:01 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: 91 lumina
Buy a vacuum gauge ($25), hook it to manifold vacuum, and look for 17-21" vacuum at idle, raise RPM's to about 2000 and hold, if reading slowly drops as throttle is held steady, exhaust restriction is indicated.(bad cat) Reading will drop abruptly, then recover when the throttle is first opened, that is normal.
Old 10-11-2004, 08:11 AM
91 lumina
i changed catalytic converter forgot to list it any ideas?
Old 10-11-2004, 11:36 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 91 lumina
try testing/replacing the fuel pressure regulator.
