lightened pullies
Anyone know where to find lightened pullies for the 2.7? I dont want underdrive pullies just lightened pullies. Thanks!
Hey I also found this article on the GT Tib its pretty interesting... http://www.sportcompactcarweb.com/fe...01scc_20gstib/ It mentioned using the limited slip diff from the SE-R (they share the save 6 speed gearbox ) Does anyone have any info on this limited slip diff or would it compare to RoadRace Motorsports lsd? If it does, its a cool $200 cheaper!
2003 Tiburon GT Haydin Oil Cooler, Hotshots Racing Header, Injen SRI, Borla Exhaust, SR BBTB, NGM Stage 4 Upper/Lower Intake Manifolds, UD pullies, Apexi Grounding kit, ARK Front Strut Brace, Nology Coolwires, kspec motor mounts, greddy oil catch can, Tein pro suspension, Tein front/rear sway bars, SAFC Neo, 15mm Hub Adaptors, Invader CF hood, centerforce stage2 Clutch, Cumstom reground cams.![]() Last edited by TiburonDelAsesino; 10-10-2004 at 03:12 PM. |
Re: lightened pullies
you need minor modification for the se-r lsd... rippmods is in the works with an lsd
check the threa about what companies have what if you search a bit you should find it |
There's a guy over at NewTiburon.com by the name of Nick Boers, he makes pulleys. Very good reputation
