Go Back   Automotive Forums Car Chat > Buick > Regal
Old 10-10-2004, 10:57 AM
jsgraves jsgraves is offline
1995 Regal - Plug wires
Doing a tune up on my Regal and noticed that that the rear three wires don't have the standard rubber "boot". they are a metal cylinder with a spring sticking out of the end, and that attaches to the plug. The replacement wires that I bought have the standard end. Whats the purpose of the metal end? Can I replace those with just the standard wires? Thanks
Old 10-10-2004, 05:24 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Re: 1995 Regal - Plug wires
The metal collar is for heat. You can pull the metal end off and slide it onto the new wires.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 10-11-2004, 10:04 PM
rollingj rollingj is offline
Send a message via AIM to rollingj Send a message via Yahoo to rollingj
The wires fit inside of the heat shields. Give the wire end a twist to loosen it from the plug (sometimes harder than it sounds). Remove the wire then remove the heat shield. Old wires tend to cause misfires once they have been tampered with. So it might be a good idea to install new ones. Apply dielectric grease to the inside of the spark plug boot and the coil boot to make wire removal easier the next time.
