Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 10-09-2004, 10:48 PM
Magm16 Magm16 is offline
01 jetta doesn't turn over, interior lights flash when trying
when i tried starting my 01 jetta it wouldn't turn over and gauges lights and interior lights flashed rapidly. tried jumping it just in case, but did not work. also keyless entry doesn't work either but did work before early that day just fine. please help!
Old 10-10-2004, 03:34 PM
bleedvw bleedvw is offline
Re: 01 jetta doesn't turn over, interior lights flash when trying
Was There Any Clicking Noise With The Flashing Lights. I Have Seen A Low Battery Cause The Instrument Cluster Lights To Flash Fast.
Old 10-14-2004, 08:05 AM
zeek1403 zeek1403 is offline
maybe the alternator?
Old 11-08-2004, 07:41 PM
hackman_vw hackman_vw is offline
Re: Re: 01 jetta doesn't turn over, interior lights flash when trying
Is it automatic? or Manual? It could be as simple as a switch or something out of adjustment.
If Automatic make sure neutral safety switch isn't bad, (possible shifter is out of alignment, check transmission for this switch.)
If Manual check the make sure the clutch switch (just like above) is working, if this switch is bad it will think that the clutch isn't pushed in.
also check voltage in battery, check that there is oil in motor (motor could be locked up?) or bad starter (test starter out of motor).
Let us know your findings.
J.
Old 03-21-2005, 03:42 PM
Greenjet99 Greenjet99 is offline
Re: Re: Re: 01 jetta doesn't turn over, interior lights flash when trying
J.
This happened to me a while back my battery terminals where not tight and caused it to act like you described. check the terminals if they are loose
