Old 10-09-2004, 10:09 PM
Technical_Automan Technical_Automan is offline
Banned
What does a bad head gasket do?
My head gasket is bad, I know because when I turn the car off, coolant is coming out right where the intake manifold connects to the block. So what problems would that cause performance wise?
Old 10-10-2004, 01:56 AM
Jm93's Avatar
Jm93 Jm93 is offline
Send a message via ICQ to Jm93 Send a message via AIM to Jm93 Send a message via MSN to Jm93 Send a message via Yahoo to Jm93
Re: What does a bad head gasket do?
actually your intake manifold doesnt really connect to the block, it is bolted to your heads, and it sits ontop of the block. a good idea to go through and put nex gaskets it, get the heads cleaned up, chanck the valves, intake refinished and so on while your at it.
http://members.cardomain.com/jm9301
It runs once more. Parked for winter.
Old 10-10-2004, 02:54 PM
86TATpi 86TATpi is offline
It could blow the engine. Antifreeze in oil doesn't make a really good lubricant for bearing in the bottom end.
