Old 10-09-2004, 09:50 PM
counts79 counts79 is offline
Send a message via AIM to counts79
Exclamation location of Spark Plugs
I have a 1996 Pontiac Grand Am 2.4L.
I need to know where the spark plugs are located so i can change them.
Old 10-09-2004, 11:18 PM
justin0717 justin0717 is offline
Re: location of Spark Plugs
Look at your engine, see where it says 2.4L Twin Cam? Remove those four bolts on that grey cover. Disconnect the connector on the right side (if facing rear of car). Then just pull the grey cover up and off. You will see four black rubber things on the bottom, if you dont see all four, then you need to reach down in the gap you see, and take them out. There are your spark plugs. When you replace them, apply a little electrical grease the the top of the plug, and then just put the grey cover back on, make sure you have all four of the rubber things on there properly. The rubber things will line up with the plugs and then you just tighten the bolts and reconnect the connector, and your done.
1996 GA SE 2.4L- sold
1999 GA SE 3.4L - newest
