| Off-Topic Talk about anything other than cars. |
exhaust 2 bolt leak
ok i have scearched the fourm and i found many answers but not one to answer this.....
the olther day i was looking at the motor hoist bracket (or whatever that plate is that mounts with 2 screws from the exhaust manifold ) ....it was corroded and surface rust, so it took off the 2 manifold bolts and the the olther bolt holding it in place. I sand blasted it gave it a fresh coat of paint and put it back on...looks great ....but when i started the car i noticed white smoke coming from where i took the 2 bolts off....now i know this is an exhaust leak...but just from removing 2 nuts and putting them back on..!!..now i was wondering do i need a new gasket or is there some kind of sealant i can use?? PS..idles normal ,but as soon as i rev past 2 grand ,the idle stay at 1500?
![]() 1998 Eagle Talon TSi AWD 6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband |
Re: exhaust 2 bolt leak
i hate when that happens you try to fix something and then things get worse
1966 mustang for sale asking $7900 call 757-766-3702 |
Har to believe you got a leak from that. Are you sure its not just the paint heating up? I'd give a week and see if it stops. Anything to do with your idle s unrelated to this of course, but I would suspect a sticking throttle plate by your brief description.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
the smoke smells like exhaust...
