Old 10-09-2004, 07:30 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question Loud pop! Possible problem??
Last night I went racing and cruising. I raced my boy in his MX-6 6cyl. auto, and LOST. How embarassing. However, I did a bad shift going from 3rd to 4th and totally messed it up.
Anywho, I was racing a Celica with 2 fine chicks in it, and when I was shifting from 2nd to 3rd, a loud POP came from the engine compartment. Scared me, but didnt stop me. It happened right when I hit the clutch. I know I need a new clutch (1 thrust bearing is gone), but it never made that sound. It was loud and kinda sounded like a backfire. Any ideas on what this might be? It hasnt done it again, everything inside looks good, and shifting is still perfect. What sup? Thanks
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 10-09-2004, 07:42 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: Loud pop! Possible problem??
sound like when u messed up that shift it got a gear stuck or somthing in the trans, and the "pop" could have been it poping back into place..
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 10-09-2004, 07:46 PM
david-b's Avatar
Dave is THAT guy
The pop was long after the messed up shift, tho. I was about 20-30 miles after the fact... I was in every gear after the fact.
Old 10-09-2004, 08:31 PM
cbell77 cbell77 is offline
sounds like a backfire check your plugs and wires.
1966 mustang for sale asking $7900 call 757-766-3702
Old 10-09-2004, 10:40 PM
bclipse bclipse is offline
You probaly backfired from your TB
95 GS-T
'cause everyone thinks they're right, and nobody thinks that there just might
be more than one road to our final destination
Old 10-10-2004, 05:10 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
YOUR THRUST BEARING IS GONE AND YOU WERE RACING!!!
dude sorry to say, if your thrust bearing is gone so is your motor! thats CW buddy.
and if your talking about the throw out bearing, you only have one! so that means something else is fucked up!
Old 10-10-2004, 12:08 PM
david-b's Avatar
Dave is THAT guy
Maybe its not the trust bearing. One of the springs on my clutch is gone. I think thats something different.
Backfires are caused by plugs? Good, I've got ome ordered anyway.
Old 10-10-2004, 12:10 PM
not just plugs but old and or corroded wires can cause your engine to miss.
Old 10-10-2004, 12:17 PM
david-b's Avatar
Dave is THAT guy
Wires are on their way also.
What's the springs on the clutch called?
Old 10-10-2004, 01:11 PM
97_3clipse's Avatar
can u crankwalk a 420a?
Old 10-10-2004, 01:39 PM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Re: Re: Loud pop! Possible problem??
Any motor ever made can walk. It's just that the 7-bolt 4g63's have a higher chance, since many of them were assembled out of spec at the factory. So yea, a 420a CAN walk, but it's not very common.
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 10-11-2004, 01:42 PM
david-b's Avatar
Dave is THAT guy
Im still kinda confused. Couple questions...
1) crankwalk is...?
2) trust bearing is...?
3) Spring on clutch is called...?
Sorry, but I just want to make sure I got my definitions down pat. Thanks
75 Monte Carlo
Old 10-11-2004, 03:34 PM
EclipseRST's Avatar
Banned
1. thrust bearing failure
2. main bearing that the crank rotates and moves one, center bearing
3. there is no spring on the clutch, there is a pressure plate and clutch disk. there is springs in the clutch disk but if those were to break your clutch would be fucked cause the spring would have no where to go
Old 10-11-2004, 07:54 PM
david-b's Avatar
Dave is THAT guy
So my mechanic is an idiot? Words from his mouth:
"1 of the springs on the clutch either popped or went out. You need a new clutch."
He said thisafter I took it in b.c. the clutch pedal makes a 'pop' when hitting it. The engine also moves alil and makes a noise when first accerating. He said that that was also the clutch being messed up. Should I get a second opinion? The clucth works perfectly fine, no slipping, still smooth. No problem.
Whats the deal?
75 Monte Carlo
Old 10-13-2004, 10:04 PM
9neon5 9neon5 is offline
Engine moving?
Check your engine mounts.
Check out the N3ON
http://www.cardomain.com/id/9neon5
