Old 10-09-2004, 04:11 PM
GvEman's Avatar
GvEman GvEman is offline
Help, with gluing front lights
On the Shelby of mine you are suppose to glue the lights on the body.. As on many other models. Does any one have any tips on how to get them on with out causing huge problems like glue on the glass...?
I was gluing my lights and the first one turned out great! but the second one... I got glue on it.. Not much.. but noticeable.
And now i am really pissed off.. i have putted down allot of work on my cf lights and then the glass looks like crap!
well, well if any one have a tip, post it.
Best Regards
Anton
Old 10-09-2004, 04:24 PM
Veyron's Avatar
Veyron Veyron is offline
Re: Help, with gluing front lights
Always use 'white glue' which is a water based glue that turns clear once it is dry.
Microscale makes a good glue called Krystal Klear.
If you mess up with it you just wet it and wipe it off.
Old 10-09-2004, 04:25 PM
primera man's Avatar
"P-Man"
Test fiit the parts first to make sure they fit correctly then add a small amount of this glue here (kristal clear) to fix your problem.
It dries clear and wont stuff up the plastic.
View All My Models Here.
Old 10-09-2004, 04:55 PM
Vric's Avatar
Vric Vric is offline
I agree.. White glue work very nicely.. I used it on my last 2 project and it was very nice.
Else, you just have to put VERY little amount of glue... the light will be fragile, but will stay in place. This is how practically all my model are done... but if a earthquake happen, I will have about 80 lens to glue again
Old 10-09-2004, 05:09 PM
p9o1r1sche's Avatar
p9o1r1sche p9o1r1sche is offline
Registered User
I use clear 5 minute epoxy to attach all clear parts, but you have to be real careful applying a minimum amount only around the rim. I use a sharpened toothpick to apply.
Old 10-09-2004, 05:24 PM
ZoomZoomMX-5's Avatar
Re: Re: Help, with gluing front lights
I used to use epoxy, but found it can yellow over time. Not bad if it's a French car, bad otherwise!
I like Formula 560 canopy glue, very strong, but very forgiving...it's a much thicker/stronger white glue, like Kristal Klear.
My Fotki Album
Old 10-09-2004, 05:34 PM
mikemechanic's Avatar
mikemechanic mikemechanic is offline
I don't know if you can get Future where you live or one of it's derivitives (sp?). It is a clear acrylic that dries rock hard and clear. I use it as often as I can to glue this kinds of things. Also see the link for other uses. The Complete Future
Old 10-10-2004, 04:28 AM
GvEman's Avatar
okay thanks for the help! When i was gluing my fonrlights i used some kind of superglue.. it was good as long as you putted on a verry smal amount of it on to the part. well well thanks again! i might order that Micro Kristal Klear from sthlm. Cheers!
Best Regards
Anton
Old 10-10-2004, 06:44 AM
proosen's Avatar
proosen proosen is offline
Hey Anton!
You could try with ordinary white glue (snickarlim), the stuff carpenters use or "Skollim" will also work. Let me now if you still needs some Kristal Kleer instead of these other one's. I use Kristal Kleer to glue my glass parts with if it's adequate, otherwise I use epoxi if I need a stronger joint. Don't ever use superglue as it most likely will frost the piece glued with it. If you now need a new headlight glass you could always reinforce the damaged part on the back side and form a new one of heated clear styrene over it. I have some clear sheets if you need it, just PM me and let me know.
Niclas
Old 10-10-2004, 07:02 AM
GvEman's Avatar
Originally Posted by proosen
Hey Anton!
Niclas
Thanks Niclas!
i have heard about "trälim" but i have not tryed it.
ye.. The glas was not that bad so i just puted it there. it cant be seen that mutch i think... well well.. i might send you and buy me a botle... but not yet.. i have alot of do before i need to glue headlights again
Cheers!
Best Regards
Anton
Old 10-10-2004, 01:09 PM
Bas Carwash's Avatar
Bas Carwash Bas Carwash is offline
Got another hint. Make sure the clear part and the place of the joint are free of any kind of dirt. Especially fingerprints. Fingerprints will turn even the clear glue white. I'll get MicroScale Krystal Clear as well, as I still need some waterbased glue. Thanks guys and good luck.
Old 10-10-2004, 08:43 PM
swollen swollen is offline
I use formula 560 canopy glue aswell.
HI! I'm your friendly nieghbourhood Mike.
Just so you know, giant pictures in your signiture make the baby Jesus cry
VW Vortex.com
VW Drivers of Vancouver
Mine = 1990 VW Jetta Xflow ...all go, no show.
Hers = 2000 Pontiac Sunfire... I know, i know
Old 10-10-2004, 09:05 PM
SchuberT's Avatar
SchuberT SchuberT is offline
Jewelers' Glue is great. It dries clear, doesn't leave frost, and the tubes of it tend to have a super tiny tiny tiny tip for precision placement.
Read the FAQ please.
https://www.facebook.com/KBModelwerks/
Call me Matthew.
