Old 10-09-2004, 03:23 AM
My92TaurusP.O.S My92TaurusP.O.S is offline
Vibrations
My car seems to vibrate when it sits idle. sometimes soft sometimes hard. i dont know if my idle itself needs adjustment or if its something else. any ideas or suggestions. or ways to possibly fix it?
Old 10-09-2004, 09:41 AM
NewsLynne NewsLynne is offline
Re: Vibrations
I have a 92 that does the same thing. I've tried .lots of stuff, it's tuned up and in good shape. I've been told the problem is that I didn't use Motorcraft plugs when it was tuned up. But I don't think that makes sense.
Old 10-09-2004, 01:02 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: Vibrations
actually, using non-motorcraft plugs can make it run rough
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 10-09-2004, 04:55 PM
Re: Vibrations
well i got over charged and had brand new plugs and wires proffesionaly replaced. im not sure if their motorcraft or not. if their not, by replacing the plugs with motorcraft ones should fix the problem? do the wires make any difference? do i need any certain type motorcraft plugs?
Old 10-09-2004, 06:49 PM
LarryKL LarryKL is offline
Re: Vibrations
Just changed the plugs in my 1999 Taurus SE Duratec with 75K miles. Pulled the original Motorcraft ones out - very well worn with large gap and center electrode worn to a little pin shape. Anyhow replaced with Autolite Double Plats and the engine purrs!
Was pleasantly surprised that it was rather easy, remove the cowling and ignition coil only. Nothing but straight ratchet without any u-joints. Highly recommend a magnetic tool for removing loosened plugs and tubing for gettng the new ones started. I had trouble with the spark plug socket stubbornly sticking to the plugs - a real bitch to get out. I was able to visually check all the rear bank using a shop mirror to insure straight alignment before torquing.
Old 10-15-2004, 12:00 PM
TomV TomV is offline
The car electronics are tuned for a specific Motorcraft platinum tipped plug per another message board I use. I have a basic 97 G. I cannot tell you any specifics about your 92. However, I would go with whatever Ford recommends. Plugs are so cheap so why not?
