Old 10-08-2004, 10:25 PM
big_sam_2004 big_sam_2004 is offline
Remote Start
Can you put remote start on a manual transmission car? if so, how does it work with the clutch and all?, i know how it would work with an automatic but a stick has always puzzled me.....
Old 10-08-2004, 11:14 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Re: Remote Start
Ive done it a few times.. If you want my honest opinion.. take that remote starter and throw it at someone you dont like.. they are NO GOOD!
But, you can get a remote starter for an automatic trans and put it in a standard and just ground out your neutral safety switch! (I dont recommend it speaking from experience, it is very dangerous)
You can buy starters specifically for manual trans. I think theyre alot more $$.. Not too sure how they work I think they just use a relay to fool the car into thinking that the clutch is in (same as grounding out the safety switch) either way its not safe.. I ran into my house once.. and sent my unmanned car across a grocery store parking lot
1991 Camaro Z28
Old 10-09-2004, 03:31 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
might also have to bypass the VATS system
Old 10-09-2004, 06:56 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: Remote Start
It is very easily done but I do not recomend it. When someone comes in my shop, it's a cash only deal.
Old 10-10-2004, 01:33 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: Remote Start
just hire a midget to live in your hatch...
*Better power-to-weight ratio than a C6 corvette*
Old 10-10-2004, 04:28 PM
92rs25th's Avatar
92rs25th 92rs25th is offline
Send a message via MSN to 92rs25th
Re: Remote Start
You can get them professionally done at like unltimate electronics and what not for like 400.00
I never had a problem with my S-10's but if you have a clutch start disengage switch , don't turn it off O.o it tends to jerk the vehicle.
I love rice so much , I eat it daily. Yum yum Civic.
1992 RS Camaro 383.
2004 Mazda 6.
2003 Subaru Legacy GT Limited.
1984 Nissan 300 ZX
1993 Mazda MX-3 ( Newest addition to my collection. )
http://photobucket.com/albums/y187/ohjiro
Old 10-10-2004, 09:02 PM
goldz28's Avatar
goldz28 goldz28 is offline
Re: Remote Start
My friend had a 95 firechicken and he left it in gear and hit a brand new honda accord. It is a bad idea...
Old 10-10-2004, 09:04 PM
92rs25th's Avatar
Re: Remote Start
If weather is an issue just get a block heater and an oil pan heater or something and you should be fine.
1992 RS Camaro 383.
2004 Mazda 6.
1984 Nissan 300 ZX
Old 10-12-2004, 05:20 PM
admin's Avatar
admin admin is offline
Lightbulb Remote Start 411
I've installed a few "remote start" alarms.. The slightly more complex (LCD 2-way) systems seem to work fine.. (I've seen a cheaper $40 or so non LCD model sit there and crank the engine for 5 minutes till it just gave up)
Some remote start alarms are for automatic trans only. Some are for manual trans only. Some do both with a cut of a wire or the placment of a jumper.. The way most alarms work for manual transmissions is the engine has to remain running once you leave the car.. To do that, you have to leave it running in neutral with the ebrake only applied (der). It then locks the doors (with no one remaining in the car hopefully). The engine then runs for like 3 or 5 minutes, finally shutting off after it's convinced that you no longer want to use the "quick run in run out" feature. Now.. As long as the doors havent been opened or a serous break in attempt hasnt been made, then you can "remotly start" your car, in neutral.. You will need a vats bypass kit, or you can just use an ohm meter and find the ohm value of your vats key chip and install a close to similar, if not exact, resistor with a relay from the remote start unit (so no one can just break the barrel and start your car).. yadda yadda yadda.. Not much more work than a regular alarm..
But As said before.. safty is always more important than this convience you lazy bumb.
My Car
I also forgot to mention that some manual trans remote start alarms want to see the ground "when e-brake is on" signal. It's the same signal that makes the "brake" light in the dash cluster come on. That it usually switched right at the e-brake leaver..
