Go Back   Automotive Forums Car Chat > Hyundai > Elantra | Avante
Old 10-08-2004, 05:17 PM
mhtnyc mhtnyc is offline
Replacing Stock Radio
Hi,
I have a 2000 Elantra GLS wagon. I'm trying to take out the stock radio and replace it with a CD player. I ordered and received a harness to go from the connector in the car to the back of the new radio with 2 ISO connectors. However, when I connect everything, the radio lights up, but there's nothing on the display and nothing through the speakers. I'm wondering if the connections in the adapter are right.
I've searched for a schematic of the plug in the car, but the colors of the wires in the car match nothing I've seen by a longshot. Here's what's in my car:
Can anyone help me decipher this?
Also: I bought the car in the US, but have since moved to Germany. Could this be an issue? Since I bought the new stereo and adapter harness in Germany, could it be wired for a possible European-type connection? Would there be any reason for that to be wired diferently from US models?
Thanks!
Old 10-09-2004, 09:47 AM
twospirits twospirits is offline
Ex-Janitor of AF
Hi, welcome to the forum,
According to Hyundai Webtech, that connector should be # M43. The diagram you provide is the male side of the connector. On Hyundai webtech they show the female side of the connector which is why the numbers will show from right to left.
This link shows you the terminals and what they go to.
Terminal No. Description
Terminal # 01 Illumination (-)
Terminal # 02 Rear Left Speaker (-)
Terminal # 03 Front Right Speaker (-)
Terminal # 04 Front Left Speaker (-)
Terminal # 05 Rear Left Speaker (-)
Terminal # 06 Power Antenna
Terminal # 07 Illumination (+)
Terminal # 08 Rear Right Speaker (+)
Terminal # 09 Front Right Speaker (+)
Terminal # 10 Acc (+)
Terminal # 11 Battery (+)
Terminal # 12 Front Left Speaker (+)
Terminal # 13 Rear Left Speaker (+)
Terminal # 14 Ground
You may want to use the troubleshooting guide here to see why its not working correctly.
Unfortunently the schematics in Hyundai Webtech do not show what the colors of the wires are, but I am certain that the connector M43 is the one in question, so the pins and their description should help you out.
TS out
Update:
Fixed Hyundai Webtech link in my post.
The more the members are involved in the process of development, the better we will be as a community of Automobile enthusiasts. Have a suggestion to make the community better, let us know.
Remember, the "No" is always there, you are just looking for the "Yes"
Members please read: Guidelines
Last edited by twospirits; 10-09-2004 at 06:48 PM. Reason: Fixed Webtech link that was not correct.
Old 10-09-2004, 12:28 PM
Re: Replacing Stock Radio
Thanks for the help. I wired everything as listed. Unfortunately, for some reason, the radio buttons light up, but there's nothing on the display, and nothing coming through the speakers. I brought the radio back to the store where I bought it, the guy tested it, and it all works perfectly.
Is it possible that there could be a problem due to the fact that I bought the car in the US, but the radio was purchased in Germany? (we moved here and brought the car with us) I was under the assumption that it should still work because it all is 12v.
Old 10-09-2004, 04:45 PM
andrew348 andrew348 is offline
Very interesting
My Wiring diagram from the factory is different than the info that has been posted They sometimes update things and dont tell anyone
pin 1 not used
pin2 Black/White Left rear speaker -
pin3 red Left front speaker -
pin4 Light green/black Right front speaker -
pin5 Black/green Right rear speaker -
pin 6 Green/black Illumination -
pin 7 Black Ground
pin 8 Brown Left rear speaker +
Pin 9 Yellow Left front speaker +
pin10 red/black Battery
Pin11 Blue/white Ignition on
pin 12 Red/blue Right front speaker +
pin13 White right rear speaker +
pin 14 green/White Illumination +
Old 10-09-2004, 06:54 PM
Ex-Janitor of AF
The link I provided above is for a 1998-2000 Elantra.
TS out
Old 10-10-2004, 07:12 AM
Here's something I just noticed: In the back of the stock radio there's a 7.5A fuse. In the back of the new unit, there's a 15A fuse. Could THIS be the source of my problems? I need to check the fuse panel in the car.
Old 10-10-2004, 08:59 AM
The fuse in the panel was a 10A. I changed it to a 15A, but nothing changed. So much for that.
Old 10-10-2004, 04:47 PM
Selenico77 Selenico77 is offline
If the radio is OK can't be any problem
I can tell you that Hyundai wire is a Standard.
There is not any type of incompatibily with the radio conections.
I do assure you, this is a simple problem, and I'm sure if you go to any Installer he will not have any problem to connect the radio OK.
Best Regards
Selenico77
Old 10-14-2004, 06:02 AM
I don't believe it. I found the problem.
Today I took the car to the shop to deal with a transmission problem. While I was there, I brought up this problem. Naturally, I plug the new HU in, and it works!! I go back home to finally finish this nightmare, and it doesn't work.
Here is where the problem was: The new HU came with a sleeve. You mount the sleeve to the car, then slide the HU in. However, in my car, there's nothing back there for the sleeve to grab onto..just 2 screws on each side. So, I took the 90° angle brackets off the old HU, and mounted them on the new one, not using the sleeve. Apparently, there's something involving the sleeve and the clips mounted to the HU that causes it not to work if not connected.
Which leaves me back at square one...trying to figure out how to mount it.
Thanks to everyone for their help in this so far!
Mike
Old 10-14-2004, 07:21 PM
Ex-Janitor of AF
Any way you can take pics of the area and upload them for us to see.
TS out
Old 10-15-2004, 05:43 AM
TS out
Actually, it's all in. The problem wasn't with the sleeve. It was with the little clips that screw to the side of the HU that the sleeve latches onto. I was able to attach the old stock brackets over the clips and screw them into the car. Everything works now! One cool thing about this HU is that it has a USB port so I can just plug a memory stick in and play tunes off of that.
