Old 10-08-2004, 12:53 PM
Noegrups Noegrups is offline
Send a message via Yahoo to Noegrups
Angry Runs rough when it runs
I have an 83 camaro and recently dropped in the entire drivetrain from a wrecked 88 IROC Z28 (according to engine code). Started the other day and the negative cable off the battery split. I replaced the cable and now the car won't hardly run. I've checked all the ground cables and they're good and so are the fuses, or at least those that I could find. The car runs extremely rough, once it warms up it will idle but as soon as you put it in gear or just give it some gas, it almost dies. The timing is correct, I've replaced the distributor, plugs and wires. Any ideas what would be causing this problem?
Cheers, Noegrups
Old 10-08-2004, 01:25 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Re: Runs rough when it runs
check the positive cable too for corrosion
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 10-08-2004, 01:58 PM
New battery and new cables, no corrosion.
Old 10-08-2004, 02:57 PM
TechX's Avatar
TechX TechX is offline
If it ran fine before the cable problem and now it doesn't I hope you didn't fry anything like the prom...etc....
