Old 10-08-2004, 12:00 PM
bill59 bill59 is offline
Question Help finding my ECU
I have a 98 cavilier and the engine light came on. I have look to see what could be happing, but when the alternator was replaced the engine light went out for 3 days. I had hoped the problem was solved, but now the light came back on. Where is the ECU on the 98 two door 2.2 and can an auto store plug in and give me what is happening inside?
Old 10-18-2004, 11:42 AM
dejaybrian dejaybrian is offline
Send a message via AIM to dejaybrian Send a message via MSN to dejaybrian Send a message via Yahoo to dejaybrian
the ecu is under the right front fender behind the evap box for the gas tank.. trust me on this one
Old 10-18-2004, 11:44 AM
Re: Help finding my ECU
So how hard is this to get to?
Old 10-18-2004, 11:48 AM
its pretty easy, but you have to take the inner fenderwells out and maybe the front facia or at least get it in the air
you definately have to take out the inner fenderwells though.. 2 bolts hold it in and they are easy to get to, the puter is wrapped in some rubber stuff, splash shields if you wish. so if you dont see it look a bit harder but it is in the right side fender well closer to the front of the car..
Old 10-18-2004, 08:55 PM
juliuszx6 juliuszx6 is offline
The two 98 cavaliers I have seen have the ecu located under the dash next to the drivers left foot.It's very easy to get to and is just clipped into a bracket.Although there should be a plug somewhere to plug into to pull the codes ,But I don't know where that is.You may want to check the alternator that was put in to make sure it is working properly.The auto parts store will do that for you,I'm not sure that they will pull the fault codes from the ecu for you.
Old 10-19-2004, 04:23 PM
godenm's Avatar
godenm godenm is offline
the reason the light went off 4 a couple days after the alt. was installed was proly cuz the battery was dis connected. the box on a 98 thats under dash is the ABS box, not the ECU. the ecu is under the pass side fender well. if u remove the pass side headlight u can see it (silver box,has the word DELCO printed on it). the diagnostics plug in is located directly under steering column(black plug).u dont hav to take ecu out 2 get the code. you take it to autozone & get the code for free & get the light reset(cutoff).
Old 10-19-2004, 04:26 PM
godenm's Avatar
if u get the code, post it on here & theres alot of people here that can help u fix it.
