Go Back   Automotive Forums Car Chat > Hyundai > Sonata
Old 10-08-2004, 11:39 AM
ty_guy38 ty_guy38 is offline
Unhappy New sterio resets when car is turned off
I just got a new Pioneer deck for my 89 sonata but everytime i turn the ignition off, the sterio resets itself, such as the clock and all settings. This is because there is no power supply once the ignition is turned off. The sterio is hooked to the direct 12v lead from the battery and the red ignition lead from the ignition switch. Is there any way that I can keep a constant supply of power to the deck once the car is turned off to keep the clock and memory functional?
Old 11-18-2004, 10:07 PM
miverson332's Avatar
miverson332 miverson332 is offline
Re: New sterio resets when car is turned off
If you have the constant hooked strait to the battery (for sure) then it should keep memory. The only other thing I could suggest is to check the ground. This is all hands on troubleshooting with an altimeter.
Michael Iverson
"Just A Fat Kid With Broken $h!t!"
Old 11-18-2004, 10:08 PM
Re: Re: New sterio resets when car is turned off
If everything turns out fine, you may want to check the stereo it's self.
Michael Iverson
