I had the 'Change Engine Oil' light flash while driving into work this morning.
Once I do change the oil, is there anything special I need to do to get the message to stop coming on? I searched the forum before this post and didn't see it this discussed. At least not with the Silverado. Read on another board that there was a procedure, but don't know if the same steps apply here. Sorry to be a pest on the boards (I really know squat about Chevys - I've only owned mostly Dodge vehicles). Thanks again! |
Re: 'Change Engine Oil' light?
yea....i believe u just turn the key half way so the power comes on , not start up, just electric. Then you push the gas pedal to the floor 3 times in a row. Turn on the key back and when u start it up again it should be fine. This is just off the top of my head, but i think its correct. It tells you how to do it in the owners manual. Please someone correct me if i gave this guy false info.
![]() ![]() 2000 Silverado LS 4.8, K&N FIPK, Gibson Extreme Dual Exhaust, Line-X Bedliner, Black Speed Grille, Viper Alarm System, Custom Audio system.... (need to update my pic) |
Thats pretty much it. I cant remember if you just turn the key on once or twice, with out starting. that puts the computer into program mode. then gas to the floor 3 times and wait. The display will flash a few times signaling it has been reset then go back to the battery display and your done. like Nigel said, try turning the key once and if it doesnt do the flash thing then turn the key twice then hit the gas sequence. If it flashes, your done.
![]() 2004.5 Silverado 2500HD 4X4, LLY, Banks 6-gun/speed brake/intake, Dual bypass oil filter, 4" exhaust, 265/75R16 Bridgestone Dueler A/T Revo2, AirLift airbags, AMSOIL in everything! 84k miles/30NOV11 Yeasu 857D/ATAS-120A - "When all else fails..." |
turn the key to run then press the gas to the floor 3 times in 5 seconds... the change oil light will flash 5 times... you're done
Exactly how it reads in the manual. Your light should reset!
2008 GMC ACADIA SLE Edition, 7 passenger model I AM Canadian!! ![]() |
On more than one occasion I've had to repeat the process to reset it. I've had to do that with an intrigue as well so keep it in mind.
06 Toyota Tundra Double Cab |
If you ever add mods such as an Cold air intake, you need to do this also as it resets the computer and will adjust to the new mods.
1998 ECSB Z71
Whelen LED's Kenwood 2-way "BIG 3" 2500+ watt audio ![]() |
Re: Re: 'Change Engine Oil' light?
I was told ..I can't remember from who that this not only resets the oil light, but also other things, but I could be wrong..probably am.
1998 ECSB Z71
when i put on my FIPK i just disconnected the battery for a few minutes and hooked it back up..as told by some people on here. When i first installed it i dident disconnect it and i wasnt gettin the performance i was expecting. But whe i reset my computer it was all good.
Hmm... I think I have been told wrong then...thanks.
1998 ECSB Z71
