Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 10-08-2004, 04:35 AM
cherry-o cherry-o is offline
Unhappy Hi! Question??Unable to use turn signal-buzzing noise occurs
My left turn signal makes this buzzing sound when I try to use it; I've replaced the bulbs and fuses but the sound remains. I've been told it may be the relay. Does anyone have any info? It would be greatly appreciated! Mahalo.
Old 10-12-2004, 10:40 PM
jeffreyb4me jeffreyb4me is offline
Re: Hi! Question??Unable to use turn signal-buzzing noise occurs
IF all the lamps work using the Hazard switch and flash normally, the problem is the turn signal switch. The contacts are burnt or dirty or the switch is failing mechanically, in any case, I believe your problem is the switch if the hazards work ok.
Old 10-16-2004, 11:56 PM
Finally, thanks to you I've got some insight!! The hazards work fine, so I'll check the switch. Thanks again!
