Go Back   Automotive Forums Car Chat > Mitsubishi > General Discussion
Old 10-08-2004, 12:23 AM
barbied barbied is offline
Conquest/Starion
Any one out there know any info on these cars? My son picked one up that does not run, and is trying to get it going...
It fires (has spark) but doesnt turn over. Looks like previous owner replaced brain box 2 or 3 times. Tried carb cleaner to induce spark, but it was a no go.
Any sites or helpful info for me??
Thanks
Old 10-08-2004, 04:51 AM
nbw nbw is offline
www.starquestclub.com or www.tristarion.com.
Sorry I cant help you further. I dont know much about them either.
*I really really wish AF had a starion/starquest section though..
Old 10-08-2004, 10:34 AM
Musashi3000GT's Avatar
Musashi3000GT Musashi3000GT is offline
Re: Conquest/Starion
This is exactly why we need a Starion Board! good luck on that problem chief, I have a alternator on my starion which I need the wiring diagram for, I posted it on both those sites mentioned over a month ago and I'm still waiting on a solid response! ohhhh well.
06 GTO: SLP Longtubes, SLP Loudmouth II K&N intake,
Ported Intake Manifold,
Ported Throttle body, MAF screen delete.
Tunned by Jeremy Formato. 381whp, 376wtq.
07 Ion Redline: Bone stock w/ factory Competition package.
In response to a race my wife had while pregnant with our baby:
Originally Posted by jeepgclwj
Prediction.... I bet we will hear about a guy down in Miami thats the King of street racing in about 18 years...Way to get him started....
Old 10-16-2004, 01:30 PM
gladihatersbro gladihatersbro is offline
1985 starion
Hey! I have a question and i am hoping you guys can answer it. I could be gettin this weeked a 1985 mitsubishi starion esi turbo. Comes with 170 hp stock and 220 ft torque. Now the guy wants 1200 or best offer.. he says there is nuttin wrong with it is a 5 spd new clutch new header new radiaiter new everything pretty much as far as engine. He says it has a small dent over the driver door but u can hardly see it but it needs a paint job. i have looked up this car and they say it is a really bang 4 your buck. It is actually a race car that in the future was made into the eclipses. hmmm anything else yall need to know jus type back....1985:
Starion LS
Starion LE
Starion ES
Starion ESI (1985½)
Conquest LE
Drivetrain Changes:
Water cooled turbine bearing housing (All)
Stronger Driveline (5 lug tire hubs on ESI )
Manual transmission change ?? model (10/85-05/87)
Manual transmission change ?? model (06/85-05/87)
Block change (09/85-end)
Chassis Changes:???
Available Colors:
Pearl Exterior w/ Blue?? Interior
Gold Exterior w/ ?????? Interior
White Exterior w/ Tan Interior (Conquest)
Burgundy Exterior w/ Burgundy Interior
Red and Black?? w/ Gray Interior
Available Options:
Auto Transmission (Starion LE, Conquest)
Air Conditioning (Starion LS, Conquest)
Technica Package (Conquest)
Digital Instrument Cluster
Electronic Voice Alert
Body Side Trim
ESI Package (actually a 1985.5 model)
170hp @ 5000rpm (SAE Net)
220ft/lbs @ 2500
7.5 PSI boost
Intercooler
Compression 7.0:1
Rear Wheel ABS (EIS only)
15"x6.5" 5-bolt Rims
P215/60HR-15 tires
Limited Slip Differential
Available w/Manual Transmission only
9.92" rotors (front), 9.65" (rear)
Steering Ratio: 14.3:1
Stabilizer Bars = .83"(front), .71"(Rear)
Technical Service Bulletins Issued:
TSB 18-52-86
TSB 21-10-90
TSB 21-18-90
I got this from a website this is all the specs. I willl try to help all of yall when and if i get 1
Old 10-17-2004, 03:37 AM
indy_85stariones indy_85stariones is offline
If you have 1987 model year or newer...
The injectors receive constant power (12 volts before the 6 ohm ballast resistor) The primary injector opens at start up because the ECU grounds the primary injector circuit. If you do not have constant power at both injectors, then you have a bad ECU relay or bad 6 ohm ballast resistor. The ECU relay is located near the passenger's side kick panel. The ballast resistor is located on the radiator support on passenger's side. If you have constant power at injectors, then the ECU has a problem. Possible that the ECU is not receiving tach signal from coil and pickup coil in distributor.
http://starquest.i-x.net
Old 10-17-2004, 01:54 PM
Thanks for the info.
I'll try the brainbox again - looks like their might be 2 bad ones in the trunk.
I'll also check that resistor
