Old 10-08-2004, 12:22 AM
DJHyperXK2004's Avatar
DJHyperXK2004 DJHyperXK2004 is offline
Send a message via AIM to DJHyperXK2004
Question White smoke??????????
Why is there now white smoke coming out of my exuast AFTER I changed the valve cover seal, and spark plug gaskets???
got rid of it spitting the black stuff, now its spits white smoke,
so i cant pass inspection
what can i do to get rid of it
the inspection guy said i might have a blown piston ring???
1990 DX Hatch
17" 5Zigen Copse Rims
CIA, 4-2-1 Header
H/F Cat, 5Zigen Exhaust
Circle Earth kit
B swap in the spring???
PIX OF MY CAR
Old 10-08-2004, 12:27 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: White smoke??????????
pull the plugs and see if one of them is oily, or if one if them is white. Oily you have a bad ring more than likely, white your burning coolent.
does the smoke smell like oil or does it have a sweet smell?
Old 10-08-2004, 12:40 AM
i just changed all those valve seals, and spark seals, no oil inside those, there dried up now,
ill check 2 morrow what it smells like..
i got 42 days to fix it
1990 DX Hatch
CIA, 4-2-1 Header
Circle Earth kit
PIX OF MY CAR
Old 10-08-2004, 12:42 AM
Forunn Daberator
oil on the buisiness end of the spark plug, not in the hole the plug goes in.
Old 10-08-2004, 09:30 AM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
burning coolant?
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 10-08-2004, 12:28 PM
CRXsiZCpa's Avatar
CRXsiZCpa CRXsiZCpa is offline
If the car was spitting out black stuff which is most likely carbon because it was running rich and you said you fixed that. So maybe now you fixed it too good and your running lean. But check the sparkplugs for oil and pop the radiator cap off and look to see if theres any oil loafing around in there.
Old 10-08-2004, 04:12 PM
Hybrid1990crx's Avatar
also check your coolant overflow container for oil. And look on the buttom of the cap for gray oily crap.
Why won't your car pass inspection? My 89 passed with a bad headgasket, and i mean BAD.
Old 11-15-2004, 10:06 AM
CRXsk8er CRXsk8er is offline
Send a message via AIM to CRXsk8er
hey man i kno how old this thread is but my car is running rich and spiting carbo i was wondering if you could tell me how you fixed the problem? i would appricate is a lot
Thanks
Old 11-15-2004, 10:19 AM
Army31u Army31u is offline
Banned
Send a message via AIM to Army31u
thatr crx is mighty mighty finel....whit smoke = blown piston ring / to much to fix so a new engine would be wise...or a new car like me:-D
Old 11-15-2004, 12:42 PM
Re: Re: White smoke??????????
Thanks
i never did, i cant figure out what the problem is.
its spits out black crap again, like crazy, was only good for a few days.
i have to fill the oil up a quart a week. sill spits out white smoke..
i just hope that cops around here dont see my failed inspection sticker
1990 DX Hatch
CIA, 4-2-1 Header
Circle Earth kit
PIX OF MY CAR
