Old 10-07-2004, 07:56 PM
ru35angel's Avatar
ru35angel ru35angel is offline
Arrow Dr/side Window is acting weird
i have a 98 GTP 4dr and for a while now I've been having problems with my driverside window.....Out of all the buttons on the control cluster the driver side window button is the only one not working properly......Goes down fine but when I need it to get it up I cant push directly down on the button but hold slightly down and on angle....? Been like that for few weeks.....
p.s. Normal temps works like that....HOT or COLD dosent work at ALL...?
appreciate any help if possible....
Old 10-07-2004, 08:08 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: Dr/side Window is acting weird
Sounds like time for a new switch. My 98 GTP would work great, then wouldn't go back up. Took it apart and put it back together and it worked fine. I'd say you are going to have to take it a part anyhow (to replace). Look for lose wires. Put it back together, but don't put it back in. Then replace if needed.
Old 10-07-2004, 08:37 PM
ru35angel's Avatar
Well I removed the the terminal from the cluster......Is there a way to take the buttons off? Someone mentioned cleaning off the terminals and also checking the clear rocker arms....? are there clips under each button?
