Old 10-07-2004, 07:03 PM
specter 23 specter 23 is offline
Crank Sensor location on 2.8
Anybody know the location of the crank sensor on a 2.8? Times like this make me wish I'd went to school for auto mechanics instead of auto body repair. Thanks
Old 10-10-2004, 05:49 PM
tomminajar's Avatar
tomminajar tomminajar is offline
Re: Crank Sensor location on 2.8
In the trunk??? I don't belive it had one.
What year ?
Old 10-10-2004, 07:20 PM
1985 pontiac firebird se. Engine won't start. Starter rotates but I'm not getting a spark to the coil. Replaced the distributor cap, ignition module, coil, plugs, wires, and swapped ecm. Very strange. It may crank right now, but not in five minutes. Never dies once it does crank. Very puzzling.
Old 10-10-2004, 07:26 PM
GTP Dad GTP Dad is offline
Pontiac Guy
The 2.8 has a CPS just not sure where it is located. I had mine repaired at a shop. The book I have indicates it is located on the side of the block. It does not say which side but you should be able to find it by following the wire from the ignition module/coils down the side of the block.
Old 10-10-2004, 07:29 PM
Thanks for the help. I'll see if I can locate it. Did you have similar symptoms?
Old 10-10-2004, 07:40 PM
tomminajar's Avatar
Easy - Pick up coil - Maybe..
The 1985 2.8 V-6 does NOT have a cps (Crank Position sensor)
Does the DISTRIBUTOR have and coil in the cap or is it external ?
FI correct ?
You could throw a 1000$ worth the parts at it and not have it fixed.
You should really start with a good manual instead of what people tell you it might be. Could be as simple as a bad 12V+ wire to the distributor.
I know the temptation is great to start and replace evrything(I've done it), but it's not real smart $$ wise.
Read your private messages
Old 10-10-2004, 07:59 PM
multi port fuel injection. External coil. No service codes. Had the ecm from another 85 2.8 I picked up for the interior and spare body parts.
