Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 10-07-2004, 06:35 PM
crx1989's Avatar
crx1989 crx1989 is offline
Send a message via Yahoo to crx1989
Exclamation Brakes stuck
I have an 86 with the drivers side rear break smoking. Do you think I have to rebiuld the caliper. The other side is fine. the parking break is a
little stiff. I just put new rotors and breaks on because the previous
owner wore the old brakes past thier limits and ruined the rotors. The old brake pads had uneven wear. On the outside the brake pad some life
left on it but on the inside it was totally shot. And on the other side of the car the brake pad was uneven where the pad was worn more on one
side than the other. The left side was worn more than the right side.
Any ideas.
Old 10-07-2004, 07:04 PM
freakonaleash1187's Avatar
freakonaleash1187 freakonaleash1187 is offline
Send a message via AIM to freakonaleash1187 Send a message via MSN to freakonaleash1187
Re: Brakes stuck
could be something to do with the brake lines, i would check that. it could also be with your master cylinder, but i would first check the lines.
-Jared
ZedEx Crew Member #2
Old 10-07-2004, 07:20 PM
crx1989's Avatar
Re: Brakes stuck
I did notice that that brake fluid was almost black. I should probably flush and replace then proceed.
Old 10-07-2004, 07:21 PM
Re: Brakes stuck
ummm, yeah, that would be a good idea, lol.
-Jared
Old 10-08-2004, 12:37 AM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
Re: Brakes stuck
i had that exact same problem with my 86 n/a... my problem was the e-break thing was seized up... i don't know how to describe the looks of it , but it's on the back of the car and there should be a steel cable coming from it that runs towards the front of the car... i just soaked it in wd-40 and hit it with something big and heavy a few times... got it unseized nicely and i haven't had a problem since! i can take pics in the morning if you would like
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
