Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 10-07-2004, 05:58 PM
camry99cw camry99cw is offline
Question dashboard air temperature control stuck on cold
Camry 1999, V6, automatic, 113k miles
dashboard air temperature control is stuck on the far left "cold air" position. if try to rotate/turn to warmer air, there is resistance, so we have left it alone.
believe this controls a cable to an interior flap that diverts between cold and warm air entering the passenger compartment. (from general knowledge, i know little about Camry)
am guessing something may be in the path and causing the flap to stick in the "cold" position???
if so, where do i look for the flap?
what do i uncover to look inside?
thank you in advance!!
Old 10-07-2004, 07:03 PM
outthere2's Avatar
outthere2 outthere2 is offline
I have access to the manual in pdf format e-mail me and I'll send the A/C sections you need
Old 10-08-2004, 01:01 AM
jspousta jspousta is offline
Send a message via AIM to jspousta
hey I think the part you might have a problem with is your blend air door (feedback potentiometers)
Old 10-08-2004, 01:03 AM
Re: dashboard air temperature control stuck on cold
if you need any info from alldata or shopkey about diagnosis or removel and installation email or message me
Old 10-08-2004, 11:55 PM
nipsirc nipsirc is offline
Please email or let us know the link where we could find some answers to the fan or AC issues.
When the fan are running, there is like a sound coming from it like something is blocking the passageway.
What could it be? How can I open the blades to check for any blockages?
Old 10-10-2004, 12:02 PM
300+ 300+ is offline
If its like my 92, that goes to both the heater hose valve and to the air mixture flap.
The valve is in the engine compartment and is easily disconnected from the cable. It can be checked for free play.
Mine actually broke in the gears on the hot cold dial.
The teeth would jump if forced. You can help it along by pushing the cable from the valve in the engine compartment.
To fix it I used a larger screw and a washer to put it back together.
Old 10-14-2004, 01:37 AM
Problem fixed, via a mechanic.
Cost: half an hour labor charge.
Work the mechanic said he did:
Checked the cable linkage. There was no obvious damage. Lubricated the cable. Works fine now.
Thank you all for your help, particularly the diagram.
Going in speaking the right words about what needed to be repaired helped.
Old 12-10-2004, 08:48 PM
docjan docjan is offline
i believe the gear in my hot cold dial broke..im planning to fix it myself.....any help
