Old 10-07-2004, 05:42 PM
LT1 Kayker's Avatar
LT1 Kayker LT1 Kayker is offline
Send a message via AIM to LT1 Kayker Send a message via Yahoo to LT1 Kayker
4x4
Ok, I saw this on Monster Garage a long while back, and I know it's possible. Im just wondering how effective it is, how much power it robs, maybe a website that sells em or something, how costly and time consuming and hard it would be to do...I dunno...any facts on it would be great.
I am pondering a 4X4 conversion for my rear wheel drive 4X2 89 C1500. Isn't it just a chain driven dealy that goes onto the driveshaft with a second driveshaft that goes to the front wheels? I know theres more to it, but I would love to hear any info on it, I wanna see my beater truck with big mudders and it being a 4X4. That would be awesome, thanks!
89 Chevy C1500 - Over 305,000 miles on her but still going strong.
Cut off cat/straight pipe.
Flo-Pro muffler. (Flowmaster soon)
Dual 3" tips.
custom intake.
chrome valve covers.
uhhh and im poor so thats all haha.
Friggin truck costs more to keep alive than I do. (4ishMPG no joke)
Wait, let me get this straight...Your honda has 1.6 liters, but my bottle of Mountain Dew has 2!?
Old 10-07-2004, 08:45 PM
goinbig goinbig is offline
Send a message via AIM to goinbig
Re: 4x4
You would need a whole new front end (one with a differential), a 4x4 tranny (or see if you can simply swap the tail of yours out for a 4x4 one), a transfer case (the chain driven dealy), and a front drive shaft.
Just to let you know, it most likely be cheaper to sell your truck and buy one with 4 wheel drive already. But yes, it certainly is possible.
Old 10-07-2004, 11:15 PM
LT1 Kayker's Avatar
Ill run over to the junkyard near here this weekend. You can get a whole suspension with both axels and differentials for like $300 or something, I dont remember. Thanks for the list though, i promised my uncle i wouldnt sell her, so this was something just to think about.
Dual 3" tips.
custom intake.
Old 10-08-2004, 07:59 AM
scoutinkeith's Avatar
scoutinkeith scoutinkeith is offline
Send a message via AIM to scoutinkeith
Re: 4x4
actuailly, this would be a good opertunity to go to a solid front axle.
you can pick the axles, T-case, and everything else that you want, and if you use leaf sprigs it should be prety easy to get it all set up.
when all else fails, get a bigger hammer.
Vehicles:
2005 suburban 1500 4x4
all stock, ex-fire department truck.
1987 Grand Wagoneer
Old 10-08-2004, 03:08 PM
LT1 Kayker's Avatar
Yeah it has leaf springs. I just hope I have enough couch cusions to dig through to pay for all that stuff, if I even find anything.
Dual 3" tips.
custom intake.
Old 10-08-2004, 05:23 PM
Re: 4x4
Youi should be able to find everything alright. Theres a lot of those trucks out there!!
Old 10-08-2004, 09:21 PM
LT1 Kayker's Avatar
How hard would that be? Im sure I could scaveng up the time after I ship the Camaro. All I would need is a jack, and then the wrenches and such to pull the whole old suspension+axels off. Im thinking of just taking off both axels and jamming in a whole new 4X4 setup under it.
Dual 3" tips.
custom intake.
Old 10-09-2004, 01:38 PM
Re: 4x4
It really wouldn't be all that hard, just be sure to set aside enough time for it. You'll also want to have at least 2 jack stands to help you out. Having a buddy or two around definatly makes things go a lot faster!
If you get the parts off of the same exact style truck as yours, everything will simply bolt right into place of the 2x4 parts.
Old 10-10-2004, 12:29 PM
LT1 Kayker's Avatar
That would be awesome, would it have to be the same year and C model, or would the same year K or different year C1500 within a certain range work too? Just in case they dont have the same truck.
Dual 3" tips.
custom intake.
Old 10-11-2004, 03:19 PM
LT1 Kayker's Avatar
Could I use the same driveshaft and tranny and all that? im looking at just the axels and suspension. or whatever I need for the whole deal.
Dual 3" tips.
custom intake.
Old 10-12-2004, 05:21 PM
LT1 Kayker's Avatar
Ive been thinking, im going to get a 350 for the truck, but will the stock tranny be able to hold up with all that, along with only a 350?
Dual 3" tips.
custom intake.
Old 10-12-2004, 06:47 PM
Re: 4x4
To make things easier, I would just look for axles from what ever range of years is the same as yours.
I'm not sure what exactly is the difference on the K model, so I can't help you there.
Some 2 wheel drive trannies allow you to swap out the tail shaft for one from a 4 wheel drive. I'm not sure if you can on yours though (maybe someone else will know). When this is done, it might affect the distance between the tailshaft and the rear end, so you might need a different driveshaft as well.
What tranny do you have? Is it a TH350 or a TH400 (not sure if any others were offered that year)? If it's either of these, it will hold up.
Also, make sure that the gear ratio in the new front end is the same as what you already have in the rear.
Old 10-13-2004, 01:52 AM
skipr skipr is offline
I can't anwser your 4 x 4 questions, but your transmission should hold up to a 5.7 litre ( 350 cid) just fine whether it's a TH350, 400 or even a 700R4. The 400 can even handle a 454 big block just fine. You probally have a 400, being that it's a HD1500. 400's where standard on 3/4 and 1 ton's, but if you have an overdrive it's gotta be a 700R4 (I think).
Old 10-13-2004, 06:51 PM
LT1 Kayker's Avatar
Its an overdrive like 4 speed. being the 4th gear is overdrive. It wont let me shift into gear one, but it lets me go to 2 d and overdrive...well thats a whole nother problem. Im almost sure its only a 4 speed though.
Dual 3" tips.
custom intake.
Old 10-13-2004, 08:22 PM
Re: 4x4
TH350 came behind 454's as well. A TH400 is extremely strong and will handle a ton of torque and power.
