Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 10-07-2004, 05:28 PM
VietBoy VietBoy is offline
stalls on neutral
hello, ive asked for help around quite abit but still cant find the solution...
my car has weird idle everytime i hold and release the brakes, the rpms would drop and make a "rumbling" sound and sometimes stall in neutral.
it stalled on me like 6-7 times today driving home and im really annoyed...
someone said it could be a bad cat converter and i did have a bad cat... changed the cat and the problem still exists...
when i was ficing my cat, the mechanic said my o2 sensor may be finished also so i might need a new one...
well back to the stalling in neutral, i asked someone and they said it is a vacuum leak somewhere and i should find it... well i dont know where to start on this
another person told me to adjust the idle speed yet i have no clue on the proper way to do this...
anyone else know any reason why my car is stalling in neutral + the solution to fix this problem?
thanks
Old 10-08-2004, 10:54 AM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
Re: stalls on neutral
I get the same problem every now and then, but I have not been able to find what or where the problem is. Vacuum leak most likely.
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
Old 10-08-2004, 01:30 PM
this also happens only when the engine is warmed up and typically happens on hot days...
problem gets worsts day after day
weird feeling when your car dies driving 50 mph on the road and a car is in front of u...
Old 10-09-2004, 01:03 AM
jdmlude_h22a jdmlude_h22a is offline
i have the same problem happen to me. it only happens in neutral. My car idles very funny also. sometimes it idles @ 1200, others it's somewhere around 750. Sometiems it even goes to zero without the car shuting off, and then just jumps back up again, when this happens i can feel a jerk in the car. Haven't talked anyone about it, because it just started happening two days ago and i've been too busy working. When someone finds out what this is, please let me know.
H22 comin' soon.
200hp is calling my name, i hear it in my dreams!
Old 10-09-2004, 07:43 AM
sofast's Avatar
sofast sofast is offline
Send a message via AIM to sofast Send a message via MSN to sofast Send a message via Yahoo to sofast
How do the breaks work? Spongy at all? You could have a small leak in the brake booster hose. That would cause it to idle funny. Check other vacume hoses as well. The pcv valve is a cheap item. Pull it up and shake it to see if it rattles. My guess is vacume
