Old 10-07-2004, 04:30 PM
TwentyPints TwentyPints is offline
Tire Pressure
what tire pressure should i use for a set of bfg mud terrian 265/75/16?
they are on a short box, reg cab.
Old 10-07-2004, 04:34 PM
korndogg's Avatar
korndogg korndogg is offline
Send a message via AIM to korndogg Send a message via MSN to korndogg Send a message via Yahoo to korndogg
Re: Tire Pressure
what does it say on the tire?? does it say 35?? i forget. i put em on all the time but i do so many cars i dont remember. i know on the truck it says 35.
1968 Camaro 327
1999 Silverado 1500 Z71 LT
{o,o}
|)__)
O RLY?
http://www.cardomain.com/id/korndogg002
Old 10-07-2004, 05:34 PM
jumpingjack66's Avatar
jumpingjack66 jumpingjack66 is offline
Send a message via Yahoo to jumpingjack66
Re: Tire Pressure
I have the bfg all terains and here is what i have found out. First the tire says 65 psi max wich is what you would run it at when loading the truck heavy or hauling a trailer. You might get away wiht running the fronts 5 lbs less when hauling but be carful. When just driving street i have tried running at 60 then 55 and eventually to 50 in the front and 45 or 47 on the back. What happens is while running higher pressures unloaded you just run down the rubber in the middle of the tires. Also stay vigilant with rotation and balancing. Leave a pare on the rear to long and suddenly on pair has a great deal less tread. My truck has posted on the door run tires at 50 lbs from the factory and after listening to some threads here on the forum i found they were right when they said stay pretty close to what came reccomended from factory. Of course my truck came stock with a lt grade tire wich requires higher pressures. A lower load rated tire ,street tires, may say less and you should follow that ecommended pressure. I think i will get the 45000 out of these tires as stated by bfg, but you sure have to pay attension to them..JJ
2000 Silverado Victory Red, standard cab, short bed, short wheelbase, 4X4, 4.8L, 5 speed, 4:10 locking rear diff, K&n FIPK, Ryno lined all the way over bed rail, heavy half suspension,factory skid plates,Fog lights, BFG 285/75/16 A/T's, dashmat, Stealth Radar.
lots of special options some installed by me!
1980 Suzuki GS1100E Super fast
Old 10-07-2004, 05:36 PM
Re: Tire Pressure
PS run any less then 45 on these and the handling of the vehicle drops away quikly..JJ
Old 10-07-2004, 11:18 PM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Re: Tire Pressure
Um..I'd put 35 in each tire. They recommend like 50 psi, but 35 wears great, handles great, and..hell, its just great!
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 10-08-2004, 12:07 AM
korndogg's Avatar
Re: Tire Pressure
i would actually recommend 45 pounds. it all depends on what is says for the truck.
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 10-08-2004, 02:59 PM
deadmeat deadmeat is offline
Call BFG @ 1-877-788-8899 choose 1 then 5. Have the info from your original tires handy (ie. size, pressure and load rating). They can calculate the appropriate pressure for you.
I am running my 275/70R16D A/T's at 45 psi as per their suggestion. They are wearing nicely and handle great.
