Old 10-07-2004, 03:31 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
Dude WTF!
So yeah, my car started knocking again, so I think to myself that some how a rod bearing already went bad somehow. I pull out the trusty stehoscope and listen to her heart beat, and I notice that sound is coming from the center of the block.
Last night I dropped the oil pan and took a look see. the pan was clean of shavings for the most part, There were some micro shavings from everything bearking in and what not, and there were some bigger chunks, however I think those some how snuck past me in the rebuild.
So anyway, I pull of the big hickey ma jigger that holds the crank in place. All of the crank bearings look good, next step is the rob bearings, grab on to the rod caps and see if any have play, nope, all of those bearings are good too, check the thrust bearings, those are cool too.
So I put it all back together even more confused than ever!
Compression is running about 240-245 on all 4 cyl., but I am running extremly rich and burning oil, due to the fact that I didn't think to change the valve stem seals when I replaced those.
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 10-07-2004, 03:36 PM
Onimacus's Avatar
Onimacus Onimacus is offline
Send a message via AIM to Onimacus
Re: Dude WTF!
oil pump?
Travis
Old 10-07-2004, 04:46 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
Re: Dude WTF!
get yourself a oil pressure gauge and see how much psi your car is kicking. If I were you just give your new motor a couple more oil changes every 500 miles and see if that helps at all.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 10-07-2004, 04:49 PM
Re: Dude WTF!
Thats some good compression, you running a high compression motor? Try switching to normal oil, not synthetic, my car seemed to burn oil when i switched to synthetic. What weight oil are you running, you might be running too thick of oil which could cause the knocking.
-2000 Civic Hatch
-1998 Lexus SC300
Old 10-07-2004, 04:57 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Dude WTF!
maby someones at the door?
Old 10-07-2004, 05:15 PM
Re: Dude WTF!
here's the deal, I have about a 9.9:1 comp. ratio. I was running good old dyno Oil 10w 30 for break-in and it was burning, then I switched to Castrol GTX, which is a semi syn. at just over 200 miles, the rings are seated real nice as noted by the compression.
I know why its burning it, it's caused by the valve stem seals, I should have changed those out when I put in new valves, but I totally didn't think of them.
but yeah the oil pressure gauge does sound like a good idea, it could be the oil pump...
Old 10-07-2004, 05:20 PM
Re: Dude WTF!
Oh yeah, my Vtec still clicks on though... so I dunno about oil pressure being a culprit.
Old 10-07-2004, 06:04 PM
Re: Dude WTF!
Aight I just took it out for a quick spin, and she got a whole lot worse real quick like, it has to be a damned rod bearing again! Guess I get to pull the oil pan off again tonight... yay
Old 10-07-2004, 08:01 PM
Re: Dude WTF!
found my problem, bad rod bearing already, there must have been a burr or something on that crank shaft when I put it together and it destroyed the number 3 rod bearing...
Old 10-07-2004, 08:06 PM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
Re: Dude WTF!
Damn man, I hope you get everything straightened out! It is such a relief to finally find out what's going on! I'm having problems with my cooling system getting real hot and building up a lot of pressure and I think it leaks out and stuff.
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 10-07-2004, 08:09 PM
Re: Dude WTF!
there air in the system, and is your thermostat opening?
Old 10-07-2004, 08:11 PM
quiXilver's Avatar
Re: Dude WTF!
well, i donno about the air, how would i know either one? it doesn't over heat untill it's just lost enough fluid
B18A
Old 10-07-2004, 09:29 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
Re: Dude WTF!
no luck for you at all
SOLD!
Old 10-07-2004, 10:30 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Re: Re: Dude WTF!
There is a bleeder valve on the water outlet on the top hose. You should crack that open while your filling it (like after a coolant change or massive loss). Once coolant starts coming out of the bleeder valve the system should be free of air.
Start the car with the heater knob on hot and cap off (top off as necessary).
After a while the coolant level will rise and you should then cap the radiatior.
GL
Old 10-07-2004, 10:31 PM
johnb16a2's Avatar
Re: Re: Dude WTF!
Blown head gasket?
