Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 10-07-2004, 02:44 PM
outthere2's Avatar
outthere2 outthere2 is offline
99 Camry Hesitation
Hi:
During cold operation the Camry hesitates from a stop. The car also gives feedback on the hiway when cold, as though the fuel is being cut.
I have changed the plugs. The Car has 107,000 kms. It gets a regular oil changes and I have purchased a new fuel filter. I know my wife uses crappy gas.
But I am wondering, from reading Brian R.'s reply to the Engine replacement thread, about the EGR Lift Sensor.
Is this "hesitation" a symptom the Sensor is failing?
No Engine light comes on during the hesitation.
I will change the Fuel Filter tomorrow and post the result.
Dan
1999 Camry CE V6 107K
2003 Jetta 1.8 T 22K ,Revo, Intake.
Old 10-07-2004, 10:02 PM
niceguy_boston niceguy_boston is offline
Re: 99 Camry Hesitation
If the symptoms go away after heating up, you can eliminate EGR..
On my 96 Camry with 81,000 miles, I found last week the opposite: Runs fine when cold, but stalls at stop signs wnen hot. Found the Engine Coolant Temperature Sensor was reporting to the Computer minus 7 F when it actually hit plus 198 F.
Get your Temp Sensor checked when cold...
Old 10-08-2004, 12:42 AM
yotatechie04's Avatar
yotatechie04 yotatechie04 is offline
Send a message via ICQ to yotatechie04 Send a message via AIM to yotatechie04 Send a message via MSN to yotatechie04 Send a message via Yahoo to yotatechie04
I agree with niceguy, check that sensor, and go ahead and change that fuel filter since it's run on crappy gas.
1994 Pontiac Grand Am GT - 3100 V6
1992 Chevrolet Lumina Euro - 3100 V6
1997 Ford Escort - 2.0 I4
"She only squeals when she's wet..."
Old 10-08-2004, 03:35 PM
outthere2's Avatar
Fuel Filter Changed
Well I changed the fuel filter today. The Hesitation is gone.
NAPA Auto reg. $76 I paid $46 CDN. not tooo bad.
I did check resistance in all the sensors I could find, Temp, EGR.
All were in Spec.
Thank's for the feedback.
Dan.
Old 10-09-2004, 12:06 AM
nipsirc nipsirc is offline
here's a similar problem with a solution from another site as quoted
"1995 Camry Stalling (update)
by "Phillip Lassiter" <plassiter@[EMAIL PROTECTED] > Oct 8, 2004 at 04:45 PM
I finally found the invoice when the dealer cured the stalling problem.
Then
I called them and asked them to explain. They said they proformed a
"Tottle
body fuel injection clean" They explained that I had carbon builtup every
where. And this fixed the stalling problem. More stuff I dont understand.
But so far so good"
