Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 10-07-2004, 12:36 PM
Gizmokid2005 Gizmokid2005 is offline
Send a message via AIM to Gizmokid2005 Send a message via MSN to Gizmokid2005 Send a message via Yahoo to Gizmokid2005
Exclamation Idling Problems with 89 Dakota
I have run out of ideas and need help.
'89 Dakota 4x4
3.9L TBI
AT
120,200
Since about April 4 I have had problems with the idle in my truck. Every time I come to a stop or slow down (below the regular idle speed for that gear) it idles at about 100RPM, or it dies. Sometimes if I wait long enough the idle will recover back to normal. From June until mid-August I never had any problems, it was fine. Ever since then the problems have been ongoing.
I have replaced:
ISCA
TPS
Ignition Coil, Spark Plugs, Wires, Distributor Cap, Rotor.
Water Pump
Belts
Computer
I have checked the timing chain, and the timing itself.
I have 3 possible problems and would like input: 1) Air pump, 2)O2 Sensor, 3)Vacuum/air leaks.
Any ideas?
Old 12-02-2004, 10:57 AM
Re: Idling Problems with 89 Dakota
I replaced the computer yesterday to no avail. It still idles wrong, but runs better overall.
Old 12-02-2004, 05:18 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Why didn't you replace the idle air control valve yet? I bet you that's all that is wrong here, and it sounds like you've spent hundreds of dollars already...
My Mopars
Old 12-03-2004, 11:44 AM
My truck doens't have one.
Old 12-04-2004, 05:35 PM
BleedDodge's Avatar
You said EFI. It must have one.
Maybe you mean TBI?
My Mopars
Old 12-06-2004, 10:51 AM
Yeah, that's it.
Sorry i've been out of it a little bit.
Old 12-08-2004, 05:58 PM
BleedDodge's Avatar
So which one is it? Get it figured out yet or what?
My Mopars
Old 12-09-2004, 10:48 AM
It's TBI.
Sorry about that.
Old 12-22-2004, 06:27 PM
BamaDodgenMX's Avatar
BamaDodgenMX BamaDodgenMX is offline
Send a message via AIM to BamaDodgenMX Send a message via Yahoo to BamaDodgenMX
I don't think you should worry about your O2 sensor. I have the same prob with my 88 D100 w/ rebuilt 3.9 So far I've replaced the TB (used), computer, O2 sensor, Vehicle Speed Sensor in tranny, as well as what youve put on. Anybody have any ideas?
Old 01-01-2005, 09:19 AM
kellydm kellydm is offline
I had the exact same problem with my 94 Dakota with about the same miles. It was a crack in a vacuum canister. The dealership fixed it so I don't know exactly what part it was.
Old 01-03-2005, 11:58 AM
If there is any way you could find out, would you? You have no idea what it would mean to me.
UPDATE: I checked my tranny fluid and added a full Quart to it and I didn't have any problems for a while but now I am low on fluid again and I am having the same problems. But I have no other ideas.
Old 01-08-2005, 01:04 PM
The only thing my receipt shows is the following:
FP Number: 55035902
Description: Resevoir 14067001
Price: $7.50
Hope this helps!
Old 01-11-2005, 10:51 AM
I'll see what I can dig up.
Thanks!!
Old 01-23-2005, 05:15 PM
stanbell stanbell is offline
I had the same problem after installing a new egr valve. When i stoped at stop signs the rpm's droped dangerously low. to the point of power loss to everything, steering brakes, all of it. I took it to a dealer to have a diagnostic and talk with " an expert". know one could help. So I put the old egr valve back in and solved my problem. The new egr valve was defective and proved to be the problem.
Old 04-13-2005, 12:50 PM
Thanks. My main problem was the front pump in my transmission was fried, and spun a bushing. So my tranny was pretty worthless. After I got that back in I changed my EGR valve, and now it runs like new.
Thanks everyone for all of your help and ideas.
