1992 Mitsubishi 3000GT
Is it good to adjust the Idle Speed (Screw on the throttle body) on a 92 3000GT.
if not what are soem possible problem it may cause. |
Re: 1992 Mitsubishi 3000GT
What are your rpms at idle?
Unless your idle is low, there is no good reason to.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
Re: Re: 1992 Mitsubishi 3000GT
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
I didn't want to , it's not my car it's my friendsand we got into an argument over it, he said that it is suppose to be adjusted every 60,000 miles or something like that, and I told him that it shouldn't be adjusted, they are set at the correct idle speed from the factory, and i told him on most vehicles u can't adjust it b/c they fill the adjuster screw in with a putty type compound so u can't adjust it. and I told him that someone prolly removed the putty stuff from his. he just got the car 3 weeks ago from the police auction, and I was wondering if the throttle speed adjuster screw on you guys 3KGT is filled or can u adjust it.
if it aint broke, don't fix it!
NO STOP DONT! lol bad idea, could offset timing leading to bent/broken valves, broken pistons, AKA $BIG. It's set w/ regard to something else I forget at the moment...but there's a reason they put that filler in there. If you adjust it without knowing what to adjust it to, you could break the internals up bad, I know that much.
Yea I know thats what I told my friend, he says his don't have the filler in it. I was wondering if all all your 3KGT's have the filler in them. cuz I told him someone prolly scraped it out. I dunno please let me know if all 3KGT's have the filler in the adjustment screw or if they do not. Joe [email protected]
