Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 10-07-2004, 08:24 AM
niceguy_boston niceguy_boston is offline
1996 Camry -- How to open Dash
The "D" light on the dash that shows position of Automatic Shift is gone.
Would greatly appreciate any one pointing me in the direction of any instructions/manual on how to open the dash above the steering wheel.
So far I have seen two screws above the steering column and one behind the Climate Temperature setting knob.
Thanks!
Old 10-07-2004, 09:36 AM
nipsirc nipsirc is offline
Re: 1996 Camry -- How to open Dash
Read this thread and you'll see
http://www.automotiveforums.com/vbul...d.php?t=296243
Old 10-07-2004, 10:59 AM
nipsirc,
All I got from reading that thread is that there are lots of folks driving around with their "D" light gone...
If I wanted to replace that bulb myself, what is the procedure for opening up that part ?
thanks
Old 10-08-2004, 01:06 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
I think nipsirc is referring to my poor description of screws under the top of the sun shield being a possible way to get to it by removing the cluster.
Old 10-12-2004, 09:21 AM
Here's an excerpt from that same thread I referred to before but with the INSTRUCTIONS.
I was able to find a detailed instruction on removal of the "Cluster Finish Panel" for the 95' Camry. Unfortunately I am not able to attach the pdf file here. The "Cluster Finish Panel" is the dark hard plastic cover that covers the instrument cluster.
There are two screws that are clearly visible on the under side of the panel just in the section in front of the instruments. According to the instructions there are two more screws just below the AC/Fan controls. To access these screws, one will need to remove the "Center Cluster Finish Panel", which is the piece of cover that surround the radio. The "Center Cluster Finish Panel" is held in by two clips on the bottom edge of the panel.
Here is a link to removal of the radio panel:
http://www.installdr.com/InstallDoc.../PDF/869013.pdf
The instruction says to "Tape the screwdriver tip before use." I assume the "taped" tip prevent scratching the finish?
