Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > Maintenance
Maintenance Discussion about maintenance issues.
Old 10-06-2004, 11:54 PM
setoria setoria is offline
Question r32 turns self off
have a gts r32 auto coupe. it runs well but every now and again it starts to misfire or just turns itself off. when the misfire occurs it only lasts for about 100 metres before the car turns off. when restarted is ok. only happens around town, on open road is ok. dash lights come on, slip in neutral and turn key and it will restart. most times straight away but occaisionally after 2-4 times. have checked ignitor and coils. replaced c.a.s 6 months ago. time between breakdowns inconsistant so no pattern. has any one come across this problem. been trying to solve it for last 12 months. mechanics not sure either. all guess work. every time i try do get it diagnosed it behaves perfectly. getting very pee'd off. help!
Old 10-10-2004, 03:54 PM
nahhh nahhh is offline
Send a message via MSN to nahhh
Re: r32 turns self off
yeah i have exactly the same probem... i dont know wtf is wrong.. everyone is telling me a different reason for the problem... it seems to be getting worse.. esp when sitting in traffic.. sometimes it almost feels like its bunny hopping.. very jerky and running really rough and then just cuts out.. has always restarted but sometimes takes 3 or 4 tries.. very annoying.. have replaced fuel filter... but just wanna know whats wrong before i start replaing expensive parts.. i dont have much money.. .. help!
Old 10-10-2004, 09:48 PM
RazorGTR's Avatar
RazorGTR RazorGTR is offline
Skyline Man
Air flow meter. 99% sure that is what your problem is.
You don't own a Skyline, then don't cry to me about it!
1992 Silver R32 GTR tickled to 450hp. - Sold when I left NZ in 2004
Arguing on the Internet is like competing in the special olympics. Even if you win, you're still retarded.
Never confuse kindess with weakness.
AF user guidelines, Please remember to abide by them
Old 12-14-2004, 08:39 PM
bob stone's Avatar
bob stone bob stone is offline
another problem i had with my old car, for me it was the electronic control for the distrubiter, chip was going bad, car would act wierd and die on me then would start right up again, after a while it was happing all the time and sometimes didnt restart.
Old 06-11-2005, 04:39 PM
Dragon GTR Dragon GTR is offline
I just got my GTR the other day and it is doing the same thing that Nahhh's is doing. Is the air flow meter hard or expensive to replace? And where is it located?
Old 12-08-2005, 12:08 AM
asianskylinefans asianskylinefans is offline
My Cefiro with RB20det did that months ago,turns out the KNOCK SENSOR PLUG was loose, check it out,its directly under the intake plenum above the oil filter,there are 2 of them first between th 1 - 3 cyl,the other between 4-6 cyl. Do a led diagnostic first there are lots of infos about this,search the forum or the NZ skyline forums. The other possibility is definitely the AFM, its going bad and even so,when you do the diagnostic the ecu will still say that its ok,but its the weakness of RB engine,the AFM.try swapping with another AFM see if your problem goes away.
Old 12-27-2007, 04:13 AM
dvsr33 dvsr33 is offline
hey guys,
i own a r33 gts and ive got the exact same problem as setoria . sometimes when im driving it will cut out then ill turn it back on and it will backfire abit then stop .. i have to wait about 2-3 minutes then it will run fine ... no fucking clue whats wrong have had full service and told my engine is fine and also changed fuel filter but it must be something electrical ? if any 1 knows what could be wrong or what i should do .. please add me to msn [email protected] thanks
Old 09-17-2016, 03:45 AM
ridonkulous_leo ridonkulous_leo is offline
Hi guys in hopes that some one still checks this
I'm having the same issue with my r32 GTR
super hard to get any help since I'm in the states and no one works on these cars here
also since I'm in california
on another post some one mentioned that they fixed this problem by replacing the power transistor
have any one else figured something out
im desperate
been 4 months of going in and out of different shops telling me the same thing
