Old 10-06-2004, 11:51 PM
failure failure is offline
Send a message via MSN to failure
Exclamation help me
i recently had a code pulled on my car and it came out a (32) bad erg valve. my dad replaced the valve and now it is worse than before! i we nt back and had the code pulled again it came out a (32) and also a (33)mapping something....??? the car is having trouble starting up and shaking when its stopped. what do i do to fix this?
Old 10-07-2004, 10:30 AM
The Right Formula's Avatar
The Right Formula The Right Formula is offline
Send a message via AIM to The Right Formula
Re: help me
Were the codes cleared after the install? Swing over to a AutoZOne if you have them in your area and they'll usually clear codes for free:-)
Gotta love the AutoZone!
--Jay
2002 Light Pewter Metallic Formula A4:
Cold Air Intake with sealed MTI Airlid, ported and polished TB, smooth bellows
Old 10-09-2004, 10:12 PM
Technical_Automan Technical_Automan is offline
Banned
Sometimes the codes have multiple possiblities as to what the problem may be and the manual will only tell you one. You can find what else the codes could be online, a quick search should bring up a few resources. (I know from experience)
Old 10-10-2004, 05:32 PM
tomminajar's Avatar
tomminajar tomminajar is offline
Re: help me
http://www.troublecodes.net
Get a mitchel manual and it will tell you how to read/fix the codes.
Old 10-12-2004, 11:20 AM
Insanity_97's Avatar
Insanity_97 Insanity_97 is offline
Send a message via Yahoo to Insanity_97
Re: help me
Thats probably the MAP sensor. MAP stands for something but not mapping, lol...in my experience you have to clear the codes after you replace the egr..and usually need a map sensor when you need an egr...
Old 10-12-2004, 11:38 AM
tomminajar's Avatar
Re: help me
Manfold Absolute Pressure = MAP - Could be as simple as a dissconnected or broke vacuum hose going to it...
