Old 10-06-2004, 10:19 PM
roach2k2's Avatar
roach2k2 roach2k2 is offline
Send a message via AIM to roach2k2
Exclamation evo enigine?
i was just wondering where i could get an evo enigine to drop into my talon?
91 Eagle Talon ESI
-new tires and rims
- rebuilt tranny
- rebuilt ECU
-LOOKIN FOR A TURBO AWD DSM! HELP ME!
Old 10-06-2004, 10:59 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: evo enigine?
There is no reason to. Make your sig shorter.
Old 10-07-2004, 01:32 AM
george536's Avatar
george536 george536 is offline
Re: evo enigine?
y would you want to? the 4g63 is the same thing.
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 10-07-2004, 01:20 PM
roach2k2's Avatar
Re: evo enigine?
cause my engine is going bad.
91 Eagle Talon ESI
-new tires and rims
- rebuilt tranny
- rebuilt ECU
Old 10-07-2004, 04:54 PM
george536's Avatar
Re: evo enigine?
juss get the 1g 4g63 again. best you can put in there.
-make your sig smaller. its anoying.
-1990 Eclipse GSX
Old 10-07-2004, 06:30 PM
Mediocrity's Avatar
Mediocrity Mediocrity is offline
Send a message via AIM to Mediocrity Send a message via MSN to Mediocrity Send a message via Yahoo to Mediocrity
Re: evo enigine?
You already have en evo engine in your car.
"ill go strate to ur house and pop my hood show u my sr20det and say see fool now lets canyon and hope u can keep up" - zeroneonzn
Old 10-07-2004, 07:24 PM
1g90gsx's Avatar
1g90gsx 1g90gsx is offline
the true evo III 4g63 comes with a bronze valve cover,16g turbo and yellow top 510 injectors.
1990 MIRAGE HB
4G SWAP
FMIC
ACT 2100
TIAL BOV
TIAL WASTEGATE
FIC 650"s
SX AFR
MAFT
INNOVATIVE DUEL BB TURBO
TURBONETICS MANIFOLD
255 PUMP
WISECO 8:51
EAGLE RODS
DELTA 272 CAMS
SETRAB OIL COOLER
AEROMOTIVE STARLITE HOSE
AUTOMETER
ROTA CIRCUT 8"S
Old 10-07-2004, 08:35 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: evo enigine?
a 4G63 is a 4G63 ,no need to fool around with a swap
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
